coolant leak between head and block at head bolt location.
I think one of my lower head bolt holes has a crack\pin hole etc, block and head are straight not even .001 warpage. It was pushing coolant between head and block when warmed up. Head gasket (fel pro 1018) seal rings are complete no tears. I see rust in the cavity for bolt in head so coolant getting up there. Chased the threads with a thread chaser very clean. I attempted magnaflux the bolt hole see nothing. I don't have access to a pressure tester.
Use RTV or pliable thread sealer? On non blind threaded holes( BBC, 302) I always use Loctite 567 with good results I just wanna do this "repair" once.
Anyone experience this?
Kobelco- Posts : 101
Re: coolant leak between head and block at head bolt location.
I’d try some sealer on that bolt and maybe spray copper the gasket.
» Water in The Oil! HELP!
» Oil Leak between block and head
» A-460 Block Oil Pressure gage port location/Back at it!!! Still lost
» coolant leak,
» Coolant temperature sensor location
» coolant leak,
