Coolant temperature sensor location
Coolant temperature sensor location Empty Coolant temperature sensor location
Post  btylerl April 12th 2019, 2:05 pm
I am installing Holley Hyperspark EFI on my '68 T-bird 429. Instructions say DO NOT install the coolant temp sensor (3/8 NPT) in the thermostat housing. The sensor needs constant coolant flow and the instructions suggest installing it in the intake manifold or block in a coolant channel. I have not been able to locate a good location and am looking for advice. I've looked at making an adapter kit in place of the short hose between the water pump and the intake manifold, but I don't believe there would be enough room.
Anyone have a success story for me?
btylerl
Coolant temperature sensor location Empty Re: Coolant temperature sensor location
Post  rmcomprandy April 12th 2019, 2:20 pm
btylerl wrote:I am installing Holley Hyperspark EFI on my '68 T-bird 429.  Instructions say DO NOT install the coolant temp sensor (3/8 NPT) in the thermostat housing.  The sensor needs constant coolant flow and the instructions suggest installing it in the intake manifold or block in a coolant channel.  I have not been able to locate a good location and am looking for advice.  I've looked at making an adapter kit in place of the short hose between the water pump and the intake manifold, but I don't believe there would be enough room.
Simply drill & tap a hole for a 3/8 pipe thread in the intake manifold somewhere BEFORE the bolt-on thermostat housing.
In the top crossover of the intake by the driver's side, next to the distributor, is usually a good place. Right in the front of a cylinder head also works if nothing is in the way.
Post  btylerl April 12th 2019, 7:05 pm
Thanks rmcomprandy! You use the term "simply" which may not apply to me, but it sounds like a good solution!
btylerl
Post  rmcomprandy April 13th 2019, 12:30 pm
Realistically, IF you can't "simply" drill & tap then that Hyperspark EFI system is also way over your head.
Post  btylerl April 13th 2019, 12:46 pm
Yeah, I just meant that drill & tap isn't something I practice daily. Can't remember the last time. Very Happy
btylerl
Post  BBFTorino April 13th 2019, 7:35 pm
Stock iron intake?
Post  btylerl April 13th 2019, 7:39 pm
BBFTorino wrote:Stock iron intake?
Yes, stock intake.
btylerl
