coolant leak,
coolant leak,
I rebuilt my 1971 429, today I started it. It ran great, but I have coolant coming out around the dipstick tube. Can I get away with pulling out dipstick tube, putting in a new dipstick tube or do I have a leak behind water pump. Water pump and timing cover are new. Dipstick and tube are on left top side of timing cover. I have searched and cannot find anybody that has had this happen. Just for info this was a low mileage engine so I re ringed it, Comp cam kit with timing gear, valve springs and lifters. 513, 520 cam. FPA headers. Bought Scotty's app for portting heads, which was much harder than I thought it would be. Edelbrock 800 CFM, Performer RPM. Used D3VE A2A heads for a little less compression. 1971 2dr Thunderbird. Sorry for being long winded. Thanks in advanced for your help.
hotrod1956- Posts : 23
Re: coolant leak,
I would guess you are missing the plate between the water pump and the timing cover. If water is leaking out your dipstick then the oil pan has to be full on water.
jasonf- BBF CONTRIBUTOR
coolant leak
jasonf, it is coming from around the tube, not out of it. There is not any oil in oil pan. I would be freaking if there was oil in the pan.jasonf wrote:I would guess you are missing the plate between the water pump and the timing cover. If water is leaking out your dipstick then the oil pan has to be full on water.
Re: coolant leak,
What is the pan full of ???? Anti freeze???? Why would you freak if the pan was full of oil??? I like oil in my pan!! I would pull the cover and check it, you would be hard pressed to put a new tube in and get it to seal on the engine, I would think. Good luck!
jeffgfg- Posts : 338
Re: coolant leak,
probably weeping down from the bypass hose
Frank Merkl- Posts : 1524
Re: coolant leak,
Might try a new cover or reseating the one you have after looking it over better for corrosion
Coolant leak
Frank I ordered a cheap aluminum water pump and paid for it. Looks like it was machined out wrong or it is for another engine. My 429/460 gasket fit the holes but not the passages. Put my steel pump back on, will start it again in morning. Thanks for the response.Frank Merkl wrote:probably weeping down from the bypass hose
» What engine coolant?
» Water in The Oil! HELP!
» coolant leak between head and block at head bolt location.
» nhra approved evans waterless coolant any users ?
» Coolant Test?
» Coolant Test?
