466 BUILD 550HP
466 BUILD  550HP Empty 466 BUILD 550HP
Post  BOSS 429 February 1st 2012, 10:29 pm
This is an old build,ill see if the sheets are around, it was parted out,and sold.maybe the info will help some of you.
4150 carb ( pro systems)
DOVE HEAD
comp roller
steel rods
cast intake (iron)
cast ehx manifolds (iron)
belt driven waterpump
was dynoed thru the mufflers,tail pipes went to the axle. lots of welding,and grinding on the intake,started with a cj.we used scj manifolds
I'll try to rem more later
466 BUILD  550HP Empty Re: 466 BUILD 550HP
Post  res0rli9 February 5th 2012, 7:01 pm
cool, what was the compression on it.
Post  BOSS 429 February 5th 2012, 7:21 pm
this had about 13.5 to 1, roller was 290 /310 .670 lift, it liked 7200 /7400 rpm
ran c14 fuel 4150 carb
Post  schmitty February 5th 2012, 7:23 pm
Pretty darn good considering a cast in and out engine with full exhaust. Cool
Post  BOSS 429 February 5th 2012, 7:27 pm
at the time it was very good, and it could ,and did drive all over
Post  rmcomprandy February 5th 2012, 9:50 pm
BOSS 429 wrote:at the time it was very good, and it could ,and did drive all over
NOW ... that's the kind of engine I'm used to and can really identify with, a drag racer with class type rules.
Smile Very Happy
Post  BOSS 429 February 6th 2012, 9:50 pm
it was kinda tuff doing the cast intake,and manifolds,went thru some bits,lol the next year we pick it up some again
