Wanted: Carb air bleed jets
I'm having a rough time tuning my carb and I need some extra blank air bleed jets as I only have 7 that I managed to scrounge from the bottom of the carb tuning bag my brother left with me. Thanks in advance
torkair- Posts : 404
Re: Wanted: Carb air bleed jets
Call Quickfuel ,I'm sure they'll hook you up.
56Tbird- BBF CONTRIBUTOR
Patrick at Pro Systems can hook up
If you are still tuning it is much cheaper to buy brass set screws from McMaster-Carr until you have determined your final bleed size(s), then order the real McCoy from Summit or whoever. I believe the size for the airbleeds is 10-32.
TommyK- Posts : 74
» Need carb jets
» Wanted Edelbrock carb
» cam or carb.? opinions wanted
» holley carb wanted FOUND THANKS
» Wanted newstyle Trickflow A460 single carb intake
