Need carb jets
Need carb jets
Need gas carb jets for 109-112. I need 4 of each and cant seem to find them on the net with jegs, summit, compcams, quick fuel etc.
Russ
423-718-3279 cell/text
Russ
Re: Need carb jets
i have boxes of them, when i get home i will check.
Re: Need carb jets
bruno wrote:i have boxes of them, when i get home i will check.
Bet you don't have boxes of them that big I think your normal kit only goes to 99.
Re: Need carb jets
bbf-falcon wrote:bruno wrote:i have boxes of them, when i get home i will check.
Rick you are correct. My kit goes up to a 99.
Re: Need carb jets
Check with Barnett they may can make you a kit up click on induction components
http://shop.barnettperformance.com/6011.tbred?page=RetailHome4&source=BAR&formaction=6011.tbred&ControlProgram=w2PITML0&tbredfile=6011.tbred&SESSION-ID=735686.00016204&LOGIN-ID=&ORDR-NUM=&CUST-CODE=0000000001&pathway=RetailLogin
Re: Need carb jets
Quick Fuel sells the E-85 jet kit and it has jets from 100 to 110 4 each, I know cause I have them and all they are is gas jets not alky jets
butterbean- Posts : 676
Re: Need carb jets
Thanks fellas, guess I will check the E85 and maybe just check the drill bit size because I hve a lot of smaller jets laying around.
» Wanted: Carb air bleed jets
» Jets for NOS wet kit
» Misc parts
» weiand carb adapter 4500 carb flange to 4150 intake
» Alky Jets
» Misc parts
» Alky Jets
