header paint
+13
ragtime
samiam
fc2444
69bluehotrod
342g
bigblok2000ranger
whitefield
jrocco
72puller
mudtrucker
17 posters
Page 1 of 2
Page 1 of 2 • 1, 2
header paint
Other than actual ceramic coating is there any diy header paint/coating that works/last ?
mudtrucker- Posts : 160
Re: header paint
Grill or stove paint works pretty good. Put a couple coats on mine at the beginning of the season and last all season.
72puller- Posts : 105
Re: header paint
mudtrucker wrote:Other than actual ceramic coating is there any diy header paint/coating that works/last ?
Eastwood has coatings that are advertised up to 1200 degrees. I have used their cast iron header coating on factory manifolds with very good success. I have not tried any of their coating on headers, but they do have good products.
www.eastwood.com
jrocco- Posts : 41
Re: header paint
BBQ grill stuff works great.
Re: header paint
I used the expensive VHT rattle can stuff and it didn't work worth a shit looked really nice til I started it. Jim (69F100) was building a truck same time as me and he used some kind of stove paint that stayed nice. I would ask him.
Re: header paint
the vht stuff needs to be cooked on at a lower temp rather than just sprayed on and fired up........IIRC The BBQ paint does not require this is I'm correct.
Re: header paint
Someone mentioned some they bought at Advance auto that worked great, I don't remember the name, I hope they get back on this thread, because I'M going to need some also.
342g- BBF CONTRIBUTOR
Re: header paint
http://xtremepowdercoating.com/index.htm is who I just had do our headers, I know its a bit more $ but the quality is very nice, & the fact that it will make the headers last longer is money in the bank.
here is a before & after
before:
after:
took about a week, & cost $280.00 total. xtremepowdercoating.com @ 972-352-5230
hope this helps.
before:
after:
hope this helps.
Re: header paint
HPC is in OKC, I just send whatever I need done with our driver and have um dropped off lol.I agree the coating is best but some like paint.................which aint nothing wrong with that.
Re: header paint
I coat headers for living, will give a good deal to members. M&R coating 865 933-1478 ask for Mike.
Re: header paint
https://2img.net/h/i1053.photobucket.com/albums/s478/sam1amiam/IMG_3757.jpg
https://2img.net/h/i1053.photobucket.com/albums/s478/sam1amiam/IMG_3758.jpg
one a these days I will figure how to post real pics,,,,,,,,, this was VHT coating, and it does very good IF you bake it on,,, my makeshift oven was good for 500 deg,and I baked them 4 times, , one full season on the headers now and still look new...............
samiam- Posts : 240
Re: header paint
fc2444 wrote:I coat headers for living, will give a good deal to members. M&R coating 865 933-1478 ask for Mike.
Where you located, and what is the cost?
Re: header paint
I hear the Snake uses the invisible kind.................
Re: header paint
The only way i've ever had any luck w/header paint is to make sure they are perfectly clean from dirt,grease and residue. Take a propane torch and heat them up,and shoot a light of paint on them before they cool down. Try to keep as much heat in them as you can while you paint. I like the in/out ceramic coating best for various reasons.
Re: header paint
richter69 wrote:I hear the Snake uses the invisible kind.................
I heard that rumor also
Re: header paint
I used Cast Iron stove paint the 2nd time, the first time I use the VHT they have 2 different kinds 1 you have to bake on and the other 1 you do not have to bake I used the one you do not bake on it is higher the the bake on.But it will scrath off very easy I have had my headers off a few times and need to be cleaned and repainted now.which will happen here in a few months when i have the engine out for the frontend swap.I may have to build another set when that happens and they will painyed to with stove paint.
Re: header paint
samiam wrote:https://2img.net/h/i1053.photobucket.com/albums/s478/sam1amiam/IMG_3757.jpg
red neck header shack................i mean that in a good way thats great man, love it!!!!!!!
ragtime- Posts : 36
Re: header paint
[quote="69bluehotrod"]http://xtremepowdercoating.com/index.htm is who I just had do our headers, I know its a bit more $ but the quality is very nice, & the fact that it will make the headers last longer is money in the bank.
before:
after:
show off................ great work, very nice!!!!!
before:
after:
ragtime- Posts : 36
powder or ceramic?
The headers shown above appear to be ceramic coated. But as you go to there website they only do powder coating.
Most powders cure at 350 to 500 degrees, but will burn off at lower temps than there cure temp. So is this what it appears or something new?
HELI-ARC- Posts : 141
Re: header paint
HELI-ARC wrote:The headers shown above appear to be ceramic coated. But as you go to there website they only do powder coating.
yes, but call them, ask for Derick, he will take care of you personally on ceramic coatings...
Re: header paint
342g wrote:Someone mentioned some they bought at Advance auto that worked great, I don't remember the name, I hope they get back on this thread, because I'M going to need some also.
I think that was Travis Rice that mentioned that paint i'm pretty sure the name of it was DEI.
Later Mark.
Mark Miller- Posts : 1955
Re: header paint
I used the VHT from Advance Auto Parts that said nothing about baking the paint on and sandblasted mine then cleaned with brake parts cleaner and handled them with Nitrile gloves to avoid contaminating them from oils on my hands. I used 7 cans and painted mine inside and out and was not happy at all after running the engine.
Some powdercoating places have extreme temp powders that can more than handle the heat from headers but it is very expensive to buy because they buy in bulk so unless they have other jobs that need to use it most will not purchase it for one job unless you want to foot the bill and if memory serves me correctly it was $2-3000 for a 55 gallon drum.
Re: header paint
Did you use the vht high heat engine paint ? that dosen't say to bake them but the vht header paint does unless the newer cans say diffrent. I tried the plasti-kote header paint and it says for 1500 degrees and it worked good plus it said you can cure it by starting the engine unlike vht which they say to cure in an oven at diffrent temps. I might give tech line coatings a try techlinecoatings.com they say it cures by air drying and good for up to 2000 degrees. Look it on youtube as well.
nuclearcobra- BBF CONTRIBUTOR
Re: header paint
Thanks Blue... I will give them a call, as it seems like the number you posted is much more in line then anyone else I have spoke to.
Page 1 of 2 • 1, 2
» header paint
» Header paint
» Off to paint.........
» PLEASE POST PICS OF YOUR ENGINES !!
» Internal engine paint
» Header paint
Page 1 of 2
