Internal engine paint
+6
bb429power
72mav
10 posters
Hi everyone,
Whats a good paint or special coating to use? Id like to seal the rocker surface of my heads when they are done soon.
Thanks.
Al
Thanks.
Al
72mav- Posts : 1081
Re: Internal engine paint
Red primer is what I have used to paint the inside of heads and the valley under the intake in the past.Some say don't put any paint inside the engine but you have to make sure they are no oil what so ever or it will peal when the engine gets hot and then you have a big problem when it starts stopping stuff up.So if you paint the inside make sure it is super clean and oil free.
no paint needed on the inside IMO
Can't remember the name but its electric motor epoxy, I wouldn't waste the time or money on it
dfree383 wrote:Can't remember the name but its electric motor epoxy, I wouldn't waste the time or money on it
That be Glyptal paint you talkin bout, its cherry red paint that you brush on. It is mainly used to increase oil return flow. But IMO just oil the parts up if anything, oil splashes all around in an engine so nothings going to rust in most cases.
bb429power- Posts : 3129
Hey, Al....I figger your time would be better spent removing some casting flash and smoothing things down a bit in critical drainback areas. If I wiped a set of bearings (or worse) and then found paint chips in my oil pickup screen , I'd never forgive myself.
maverick- BBF CONTRIBUTOR
X2, take a deburr kit and do thing like radius the oil return holes and smooth the paths to them.
internal paint
Eastwood sells it, it was developed by GE for electric motors, I think its called Gliptol something like that. Block has to be totally clean to stick properly. I think the same stuff was used inside the 9" Ford carriers, same reddish color.
blown473- Posts : 376
If it was mine Al I wouldn't do a thing,But,if you must,then use the Glyptol or whatever it's called. And yes most all elect.motors are painted w/it. I would'nt put anykind of paint in the inside of my combustion engines.
Personally this is a waste of time, it not only cost time and money, but what if it flakes off and gets in your oiling system and wipes a bearing? Then you just payed to crater your own engine......
If you feel you need better oil control polish the valley, other than that leave it alone.....
the Coug- Posts : 3055
Glyptal
Ok I have worked in the industrial electric motor businness for 18 years I have seen literaly millions of endplates
stators armatures painted with glyptal. I have built my own engines and many of my friends in the past 30+years AND NOT ONE OF THEM WAS COATED WITH GLYPTAL!!!!!!!!!!!!! There are a bunch of reasons why
very simply put polish and remove the casting flash clean up the oil drainback holes and leave the glyptal for
what it was intended for electric motors. Please take my advice as it is one of the the few times I will call myself a expert on any subject.
Steve
Steve
70429scj- Posts : 348
Thanks for the replies guys.
I well planned to de-burr everything anyway. Reason I wanted to coat the heads was to keep the rust away untill I get them on the short-block. But Ive found a special storage coating from Goodson that Im gonna try.
If it was me, Id just bag em and put them under my bed. The WIFEE wouldnt go for that
72mav- Posts : 1081
Wanna see what's under my bed? I assure you there are no monsters, I brought everything out to check inventory. The intake, carb and air cleaner is on a table in my room so when I wake up I see that along with some other engine parts. Warning! There are a lot of links!
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180001.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800012.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800013.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800032.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180004.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180005.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180006.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180007.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180008.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800092.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180009.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180010.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180011.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800122.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P51800132.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180013.jpg
https://2img.net/h/i976.photobucket.com/albums/ae245/bb429power/P5180014.jpg
Justin if when you link the photo bucket here you can go to the post img and it will post the pictures not a link.....
I know, but I had so many links and I didn't want it to take forever to load and take up a bunch of space. Should I put it in the IMG format?the Coug wrote:Justin if when you link the photo bucket here you can go to the post img and it will post the pictures not a link.....
» Dark Blue Engine Paint ?
» internal balancer
» CRANKSHAFT BALANCE.
» WTB 460 CRANK SNOUT COUNTER WEIGHT
» Internal balance??
» internal balancer
