need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
5pointslow
well gonna do the internals over .... im not sure i wanted to use stock rods and crank
i have a d1ve block filled to bottom of freeze plugs
.030 over bore
dove heads ( ported with 2.250 intake)
using a solid roller - gonna have ground for my combo
viktor intake
gonna either do a 521 with a 4.3 crank or a 4.5 crank and have a 545
this engine is studded on the mains , and is gonna get hell fire rings and spray a 200-250 shot ( and yes its a JEFF PROCK plate 8 )
gonna use cast crank from scat with there h beams
just wanna know for what im using it for and the block is there any pros and cons of the 2 cranks dont wanna spin past 6500-7k if needed
.030 over bore
viktor intake
5pointslow- Posts : 1408
Re: need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
cast I'd do a 4.3
Just something to point out if the budget is the reason for the cast crank.
If you plan to internal balance it, the cost to balance a cast crank is higher than a 4340 forged crank. By the time you pay for the extra heavy metal needed for the cast you will be within $2-300 of a forged crank, which does not require heavy metal to balance.
That said, with the cost of 4340 cranks where there are now I would not use a cast crank for anything that sees much track time. The small cost diff is a long term bargain. X10 for anything that is going to see some spray.
lets just say the stock crank will stand up to more than the cast stroker crank....JMHO
the Coug- Posts : 3055
richter69 wrote:cast I'd do a 4.3
X2 ... balance the front of the cast crank internally and the rear externally.
Get it from Adney at "Performance Crankshaft"; he is very familiar with this process - 1 (586) 549-7557
X2 on getting the crank from Adney and I suggest going forged, JMO.
For the record I'm running a 4.31" Forged crank from Adney
D. Sea- Posts : 2768
D. Sea wrote:For the record I'm running a 4.31" Forged crank from Adney
Overachiever
schmitty- Posts : 4538
was only gonna go cast ... thought i heard there good to 850 - 900 hp ?? scat ones ..... i dont have a prob going forged but was looking at the $ to have into a d1ve block i mean its only 2bolt with arp studs and ported doves ??? i mean is it just as easy to make good power using stock crank and putting h beams and pistons in .......9.50 index car !!!! my applied nitrous (jeff prock) plate can go as little as 150 shot ...just looking to run in that class
You are somewhat correct as long as you also keep it all financially correct. (TOTALLY internal balancing a cast stroker crank is not a good decision when the cost of installing Mallory metal is considered).
It seems in the high performance world that most want to make everything they can over-engineered; the proverbial "Brick $hithouse".
schmitty wrote:D. Sea wrote:For the record I'm running a 4.31" Forged crank from Adney
Overachiever
I got one as well...............
Overachiever twins.richter69 wrote:schmitty wrote:D. Sea wrote:For the record I'm running a 4.31" Forged crank from Adney
Overachiever
schmitty wrote:Overachiever twins.richter69 wrote:schmitty wrote:D. Sea wrote:For the record I'm running a 4.31" Forged crank from Adney
Overachiever
And don't you forget it! BTW I'm Arnold.... He is Danny
» can't put details of combo together, need input
» my plans for my 10.00 index spare engine build , thoughts and ideas
» ENGINE COMBO QUESTION
» need help asap with crank trigger
