my plans for my 10.00 index spare engine build , thoughts and ideas
using a spare d1ve block
4.3 eagle cast crank
eagle h beam rods
need to get pistons (13.1-13.5.1 hopping)
oiling mods to block done
dove heads they have port work done (not sure flow #s ) they have 2.250 intake valves ect (gonna have spring pockets done for roller springs )
and get a custom roller cam
car is a fox mustang cm cage , thru floor frame connectors cert to 8.50s , mini tubbed , strange brakes front and rear , racecraft k member and drop spindles ect
coilovers car weighd in at 2800 with me in it with a 408 it before and that didnt have the new brakes or spindles .....prob 2900 ish with iron headed bbf id guess
glide 1.80 trans brake
champion wheels 15x12 rears single beadlock on 29.5 x10.5s
do ya guys think its doable , i need an intake and carb .........hope i dont need any more head work porting that is
im gonna take some pics and move to the build section this weekend
thanks andrew
eagle h beam rods
thanks andrew
5pointslow- Posts : 1408
Re: my plans for my 10.00 index spare engine build , thoughts and ideas
Index stuff is kinda tuff, you need alot more motor than just something to push it to a 10.0...... but it sounds like you'll be close.
ya guys know of what kind of power roughly to 10.00 index at 3000lbs give or take prob be a hair under that
630-650 should put you in the high 9s you'll need a couple tenths wiggle room to compensate for DA and varying track conditions.
IMO 675-700 would be Ideal, get you in the 9.60-9.70 range, that give you comfortable wiggle room for weather, DA and temp changes.
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» Thoughts on this build - A head 533
» top end setup and cam ideas for my 557 build.
» Looking for ideas on how to build a high compression 429
