Looking for ideas on how to build a high compression 429
bb429power
501ranger
I am in the planning stages of building a 429 engine for class racing. I would like a high compression 429 to run on alcohol, but I am not finding a large selection of pistons for the 429. Is a custom piston my only choice? Are there any odd ball combinations with a 460 piston and a diiferent rod that should work?
501ranger- Posts : 54
Re: Looking for ideas on how to build a high compression 429
The main reason I decided to ditch the 429 crank and swap in a 460 setup was this exact reason. But I was looking for low compression, have you checked Diamond pistons or Keith Black yet? I know KB has a couple of them, they are Hyperuetectic though.
bb429power- Posts : 3129
I need to stay with a 429 so I can stay in a certain class. I would like the extra strength of a forged piston.
what cyl heads?
Yes, you can start with the TRW L2443 dome-top piston (which is meant to be used with a 460) and fit it to the 3.59" stroke 429 crankshaft via the common Chrysler 440 "LY" connecting rod (6.76"). With ported, large-valve D0VE heads, you will end up with about 13.5:1 compression ratio, which is pretty nice for alcohol. The componenet stack height is 10.315" nominal, so any D1VE or D9TE block is suiatable.501ranger wrote:I am in the planning stages of building a 429 engine for class racing. I would like a high compression 429 to run on alcohol, but I am not finding a large selection of pistons for the 429. Are there any odd ball combinations with a 460 piston and a diiferent rod that should work?
In order to do this setup:
- The 440 LY rod will need to have the pin end bushed down from the Mopar 1.094" pin diameter to the BBF 1.040" pin diameter; bushings are readily available, and,
- The 429 crankshaft's 2.500" Ford rod journal diameter will need to be reduced to the Mopar 2.375" rod journal diameter, at which point a standard Mopar bearing can be used.
Paul
George Keown has a set of .030 429 pistons with some healthy knots on top of em
56Tbird- BBF CONTRIBUTOR
Diamond only has 4 429 pistons and they all have 3 cc domes.
richter69 wrote:what cyl heads?
DOVE heads
I helped a buddy degree a cam in his 429 deal here a few winters ago, he had some kind of Wiesco dome in it if I recall.
I'm sure Diamond has or can do whatever you want if money is not a huge concern lol.
the mopar rod deal paul spoke of works pritty well.IMO
Yeh, and it's an inexpensive shelf dome-top piston, OEM crank and rods. (C-H-E-A-P.) Of course, depending on intended horsepower & rpm you could go with an aftermarket rod. Still cheap. And strong.cool40 wrote:the mopar rod deal paul spoke of works pritty well.IMO
Paul
The engine would be in a 4400 pound sand/dirt drag truck. I would like 550 or 600 horsepower to be competitive. So far the parts I am thinking about using include a big custom solid flat tappet cam, victor intake, 5000 rpm convertor, 2 inch headers, forged pistons and ported DOVE heads. Do you guys think that’s a reasonable goal for the given parts?
It can be done; pulling it off will be dependent on the knowledge and details that go into the build. It would be nice if that Victor intake has a 4500 top.501ranger wrote: I would like 550 or 600 horsepower to be competitive...he parts I am thinking about using include a big custom solid flat tappet cam, victor intake, 5000 rpm convertor, 2 inch headers, forged pistons and ported DOVE heads. Do you guys think that’s a reasonable goal for the given parts?
Based on your latest post of engine/power needs, I still feel the Mopar rodded L2443 combo is the way to go in your case.
Paul
Paul, do you think a smaller cu. Inch motor like a 429 would be a better choice with dove heads appossed to a bigger 460, or even a 500+ stroker ? I dont want to get into a p@!ing match about desk top dyno but it seems that when you drop the cubes it will make more power at a higher rpm.
mudtrucker- Posts : 160
FWIW, I can have the pin location moved on the 460 dome pistons that Diamond makes for me so they'll work with a 429, and for a heck of a lot less than a full custom.
Carl- Posts : 284
I did the same thing before, it seems to be the shorter stroke makes it wind higher. I've been messing around with a big bore short stroke combo on there, the software is just a guideline to me. But fun to mess with. I don't want to start anything either, so no one be hatin!mudtrucker wrote:Paul, do you think a smaller cu. Inch motor like a 429 would be a better choice with dove heads appossed to a bigger 460, or even a 500+ stroker ? I dont want to get into a p@!ing match about desk top dyno but it seems that when you drop the cubes it will make more power at a higher rpm.
The topic starter stated that he needs to stay 429 due to a diplacement rule in the class he races. The class is sand drags or mud drags, and I don't know anything about that sport and so generally speaking I don't know what the best engine combo might be.mudtrucker wrote:Paul, do you think a smaller cu. Inch motor like a 429 would be a better choice with dove heads appossed to a bigger 460, or even a 500+ stroker ? ....it seems that when you drop the cubes it will make more power at a higher rpm.
As far as diceplacement in general goes: Assuming no other changes except displacement, the smaller engine will make similar power at a higher rpm, yes.
Paul
These are awesome pistons and it's good to know this, Carl. I was actually hoping to do the Mopar rod 429 deal with your Diamond 460 dome-tops for an 8500 rpm engine for a class that dictates OEM stroke; I am happy to know they can be ordered with a 429 pin location also.Carl wrote:FWIW, I can have the pin location moved on the 460 dome pistons that Diamond makes for me so they'll work with a 429, and for a heck of a lot less than a full custom.
Paul
Big bore short stroke was the claim to fame for the 427fe's, twist it till it screams and then hit 2nd gear!!!!!!!!!!bb429power wrote:I did the same thing before, it seems to be the shorter stroke makes it wind higher. I've been messing around with a big bore short stroke combo on there, the software is just a guideline to me. But fun to mess with. I don't want to start anything either, so no one be hatin!mudtrucker wrote:Paul, do you think a smaller cu. Inch motor like a 429 would be a better choice with dove heads appossed to a bigger 460, or even a 500+ stroker ? I dont want to get into a p@!ing match about desk top dyno but it seems that when you drop the cubes it will make more power at a higher rpm.
I ran it this year with a mild 501 stroker and was put in a pretty advanced class. I think I would have needed atleast 800 hp to be competetive in that class. By reducing the engine size and using more stock replacement parts, I can drop down to a slower class.
I usually build pump gas engines, this one will be my first attempt at running alcohol. How much compression should I shoot for on alcohol?
» top end setup and cam ideas for my 557 build.
» High compression and dual batteries
» Ford Aluminum SCJ Heads/High Compression?
» High compression topic, dish vs flat top vs dome.
» my plans for my 10.00 index spare engine build , thoughts and ideas
