C4 Hold up on the street?
C4 Hold up on the street? Empty C4 Hold up on the street?
Post  512Fairlane February 6th 2012, 10:51 pm
Would a basically stock C-4 hold up behind a 450 HP 460 on the street? I have a C-4 and it would fit the trans tunnel of the 57 much better than a C-6. It has a shift kit but otherwise its pretty stock I believe.
512Fairlane
512Fairlane
C4 Hold up on the street? Empty Re: C4 Hold up on the street?
Post  richter69 February 6th 2012, 11:08 pm
as long as the line pressure and clutches/bands are up to snuff I dont see why not.
put a deep pan and a huge cooler on it...........
Post  whitefield February 6th 2012, 11:09 pm
It will need a deep pan , good cooler,and lines. You won't be able to run much of a stall or hammer on it a lot. you will need some line psi around 180 or better. If it has the 3 on 4 clutch set up it would be a waist of time and just make you mad.
Take it apart and make sure it has at least 4 on 5 clutch packs and all of the above stated stuff and I think it will be fine! good luck
whitefield
whitefield
Post  superchargedv8 February 8th 2012, 3:27 pm
I would emphasize the cooler...make sure you get something that moves a good amount of air..
superchargedv8
