7 bolt valve cover heads
Can I use 6 bolt big block fabricated valve covers on a head with 7 bolt holes, can get a deal on them hope I can use them.
3stangs- Posts : 2
Re: 7 bolt valve cover heads
Is it the middle hole on the intake side of the valve cover that's missing?The Ford Racing 429-460 Valve covers only have 6 holes in them.
Later Mark.
Later Mark.
Mark Miller- Posts : 1946
yes it is the middle top bolt on intake side of the valve cover, guess they will work, shouldn't have alot of pressure up there you would think just two bolts would keep it from leaking oil. Thanks for your time Tom
3stangs- Posts : 2
» valve cover bolt holes
» Valve cover help for the scj heads
» What are the options for a low fabricated valve cover for c heads
» How bad would the 2 inch foxbody headers hurt a 800 h.p. 521? Here some engine specs and Ideas.
» valve cover studs for aluminum valve covers
