valve cover bolt holes
Am I correct, all scj and PI heads have the valve cover bolt hole that goes through into the intake port?
rcasonbbf- Posts : 26
Re: valve cover bolt holes
I know for sure the SCJ's do not sure on the PI's I didn't think so.
jeffgfg- Posts : 338
I've had 2 sets of pi heads and seem 3 or 4 sets of scj heads. All had them. I'm talking aboutcast iron heads.
I was talking about factory cast iron heads also. I wasn't sure about the PI's. I know that the SCJ's did from trying to start my SCJ torino with just a couple of bolts in to hold the VC in place to warm it up to set the valves, wouldn't idle at all and barely ran.
I was reading it wrong. Sorry jeff
Someone on eBay was asking if there was a hole in intake port?
Yep the 2 end intake ports where the valve cover bolts are were drilled through to the intake port.
Only a few more to go!! See how easy that was????
» 7 bolt valve cover heads
» Silicone in head bolt holes - how to remove?
» valve cover studs for aluminum valve covers
» Victor 4500 intake for sell , no stripped bolt holes $225.00
» Timing Cover Bolt strength
