oil pump ?
oil pump ?
will this one work for canton oil pan in mustang part M84DHV Melling ?
bigjohn2007- BBF CONTRIBUTOR
Re: oil pump ?
I'm not familiar w/canton pans .Do you have pic's of the pan and pu tube?
Re: oil pump ?
it should. That is the same pump recommended for fox body Moroso pan rear sump. Go to Canton website and look up your pan and it will give you the oil pump part # for that pan.bigjohn2007 wrote:will this one work for canton oil pan in mustang part M84DHV Melling ?
stanggt- Posts : 494
Re: oil pump ?
thanks guys
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» Fuel Inj. Pump - Ron's Black Gear Pump - Size "0" - SOLD !!
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
