bb fox manual brakes
i just installed manual brakes on the bb fox. the master cylinder only has 2 ports. the oem one has 3. sorry if this is a newb q. can someone shed some light on this?
much appreciated
much appreciated
7ohhhh- Posts : 7
Re: bb fox manual brakes
You need to add a "T" in the front to split the lines left and right. A proporting valve will be necessary for the rear line.
Jess
Jess
Mustang-junky- Posts : 438
If your using the factory proporting valve you can take the plug outta the back and run the brake line there.
nuclearcobra- BBF CONTRIBUTOR
» Rear brakes upgrade 8.8 and manual brakes, M.C. and factory swap disc??
» Manual brakes
» Need to convert to manual brakes
» Brakes
» I need ideas for my foxbody manual brakes
» Manual brakes
» Brakes
