Cam advice?
Cam advice?
Asking for a friend. Have a stock bottom end 460 with d3 cylinder heads and exhaust humps ground out and weiand stealth intake with a 750 vac sec.
Trans is a c6 stall is based on cam. Its going in a 70 F100 with a 3.73 gear.
Would like a little bit of a lumpy idle and make good power throughout power band.
What would you guys reccomend? Thanks in advance
80hatchstang- Posts : 8
Re: Cam advice?
80hatchstang wrote:Asking for a friend. Have a stock bottom end 460 with d3 cylinder heads and exhaust humps ground out and weiand stealth intake with a 750 vac sec.
230-236 @ .050 flat Hydraulic on a 108 or 110 sep .550-.560 lift works good on a flat top D3 headed deal, probably won't even need a stall converter other than like a 6 cyl. stock type converter.
There will be several suggestions coming, but this is what I like for a strong street driver.
COMP XE-274H is a good running cam.
Re: Cam advice?
Have the valve guides been machined lower. If not, you've got to keep the valve lift BELOW .540".
A "custom" would be the best option and the cost is NOT much different.
Blake's duration figures are about right with around stock compression ratios; slightly optimistic if anything.
» ok truck guys i need advice come on in heros need motor advice also
» Need advice
» I need advice on my ignition
» Need some advice
» building serious bbf need help and advice
» Need advice
» Need some advice
