A460 rocker studs?
powerstrokeace
A460 rocker studs? Empty A460 rocker studs?
Post  powerstrokeace February 20th 2012, 11:22 pm
Ok since I'm freshening the motor i figure I'd replace the rocker studs as you can see somebody really cranked down on the polly locks and for piece of mind. The studs I have don't measure up to the TFS or ARP spec's. Matter of fact the TFS stuff don't measure up to the ARP stuff as well. So the studs I removed from My heads has a lower base length of 1" and no centering shank for the guide plates. I was hoping to get a lower base of 1" instead of .750 on the TFS stuff just for extra strength. So why put ARP's name on some thing you can't get from ARP? just thought I could save a buck or two Buying ARP's stuff rather than TFS
Ace
powerstrokeace
powerstrokeace
A460 rocker studs? Empty Re: A460 rocker studs?
Post  dfree383 February 21st 2012, 12:13 am
Lem typicaly has the TFS ones. They are a Bastard legnth the TFS get made by ARP.
Post  powerstrokeace February 21st 2012, 1:26 am
dfree383 wrote:Lem typicaly has the TFS ones. They are a Bastard legnth the TFS get made by ARP.
I know they are made by ARP but only for TFS and they get to charge double for it. This sucks
Ace
powerstrokeace
powerstrokeace
Post  c.evans February 21st 2012, 2:18 am
Well the worst thing you can do is put a generic ARP part number such as the old 1701 in the heads. The TFS studs are propriority parts made by ARP, but they are taller for a reason. That reason being that you will have proper rocker arm geometry for the 2.00" installed height, and have plenty of threads of engagement for your polylocks.
IMO if, if, they charge double it's worth it. Phillip and I "saved" a truck pulling engine that had cast iron EX 514 A-460 style heads,,,,and too short of a rocker stud,,,,by buying and installing the taller TFS rocker studs on the EX 514 heads. Of course then we had to install longer pushrods also, but together they solved all the geometry problems on a screwed up engine that came in here to be dynoed.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bigblok2000ranger February 21st 2012, 3:15 pm
I just bought the TFS studs for my A460's through Summit yesterday, kinda wierd deal there the TFS-54400614 = 16 studs@$129.99 but TFS-54400614-8 = 8 studs@$51.99 I bought 2 sets of 8 for almost $30 savings.
bigblok2000ranger
bigblok2000ranger
Post  Lem Evans February 21st 2012, 3:45 pm
Did any of the studs you bought have the 1.250" base thread lenght?
Post  Lem Evans February 21st 2012, 9:30 pm
54400614-8 = $51.95 - 8 studs with standard lenght base threads.
54400615-8 = $84.95 - """""""""""""" 1-1/4" """""""""""""""""""""""
54400614 = $129.95 16 studs - 8 with standard base & 8 with 1-1/4" base threads.
The difference in price is the lenght of the studs.
Post  138 February 21st 2012, 11:46 pm
Should of just called B.F. in the first place...
138
Post  powerstrokeace February 22nd 2012, 12:20 am
Lem Evans wrote:5440014-8 = $51.95 - 8 studs with standard lenght base threads.
5440015-8 = $84.95 - """""""""""""" 1-1/4" """""""""""""""""""""""
5440014 = $129.95 16 studs - 8 with standard base & 8 with 1-1/4" base threads.
Lem Are you missing the 6 in the part numbers you listed?
54400614
54400615
not sure what the last number is.
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans February 22nd 2012, 12:25 am
I fixed it....I'll never make it as a typist Smile
Post  bigblok2000ranger February 22nd 2012, 10:24 am
I have the Motorsport A460's, I called Trickflow and they said that the older heads used all 16 studs that are the same and the 54400615 was for the heads produced within the last year or so.
bigblok2000ranger
bigblok2000ranger
Post  powerstrokeace February 22nd 2012, 9:23 pm
bigblok2000ranger wrote:I just bought the TFS studs for my A460's through Summit yesterday, kinda wierd deal there the TFS-54400614 = 16 studs@$129.99 but TFS-54400614-8 = 8 studs@$51.99 I bought 2 sets of 8 for almost $30 savings.
I got the heads studs using my pro racers discount and paid $45.45 per set of 8. thank for pointing that out.
ACE
Last edited by powerstrokeace on February 23rd 2012, 12:50 am; edited 1 time in total
powerstrokeace
powerstrokeace
Post  Lem Evans February 22nd 2012, 9:49 pm
I got the heads studs using my pro racers discount and paid $45.45 per set of 8. thansk for paointing that out.
ACE
Which set of 8?
Post  powerstrokeace February 23rd 2012, 12:52 am
the Intakes. 54400614. After placing the order I should have got the long exhaust and cut them to 1" on the stud base side. But oh well is should be fine.
Ace
powerstrokeace
powerstrokeace
