Head Studs with T&D Rocker A429
ARP head studs are too long to be used with the T&D shaft rockers. (There is actually a footnote on the T&D page mentioning head bolts to be used)
Does ARP make any slightly shorter head studs?
5.25" is what mine measure out.
It looks like a 5.00" stud would work fine (with the smaller 12 point nuts)
Advisable to stay with head studs? Or just get head bolts?
Valve tip pattern look great when set up:
68galaxie- Posts : 351
Re: Head Studs with T&D Rocker A429
You can order any length from arp
It's very common to have to cut the fine tread end of the studs when using shaft rockers.
Just cut what you have.
kim- Posts : 700
