BBF 460 Questions
BBF 460 Questions Empty BBF 460 Questions
Post  neilp February 21st 2012, 8:24 am
I am looking at putting a 460 into a 1932 Ford, with engine and trans these cars weight approximatley 2500lbs, not sure what gears I will run yet since the tires I decide on will dictate that.
My questions are that I have found an engine from a 1973 Lincoln Mark 4, what is requried for this eninge to make about 350rwhp? The first engine build will be on a somewhat budget so I am curious about swapping heads from pre 1971 460's. There will be no AC or power steering or any smog control, as well as an electric fan so this should free up a few ponies. It will be fuel injected so a carb will not be an option.
neilp
BBF 460 Questions Empty Re: BBF 460 Questions
Post  bigblockfox468 February 21st 2012, 9:19 am
Welcome aboard. It shouldn't be too hard to achieve your goal. Read this and get to know some folks around here so you know who is who and ask away Wink .
https://www.429-460.com/t121-big-block-ford-horsepower-chart-info-gathered-by-djohagin
We have a member here who is doing up a similiar street rod build. He goes by patfrom jersey and has a thread about it in the General Section. That would be a good contact to start with. Good luck and keep us posted and we like pictures Exclamation Laughing
bigblockfox468
bigblockfox468
Post  rmcomprandy February 21st 2012, 12:30 pm
Getting 350 at the rear wheels will be somewhere around 450 at the flywheel and that is pretty straightforward; (although many different ways to get there).
