AWW yeah just bought a cast eagle crank for 249.99$ from adperformance
5pointslow
figd if im gonna throw this engine together with my spare parts to run 10.00 index
it might be a lil easier with more cubes
4.3 stroke crank eagle cast ......my luck it prob break but id fig at that hp level in a 2800 lb car to run 10.00 it be okay with just studs on 2 bolt mains
already have a used set of eagle h beams 6.7 , gonna order some new pistons to bump compression up
fig id need 650hp to do it
englishtown nj here i come ............lil old iron 521
5pointslow- Posts : 1408
Re: AWW yeah just bought a cast eagle crank for 249.99$ from adperformance
Keep the bolts for the main caps......others will probably say the same
650 HP....won't even touch that crank as long as your tune is good
John Myrick- BBF CONTRIBUTOR
dont use studs use bolts ?? realy???
For your reading pleasure.....enjoy
http://www.460ford.com/forum/showthread.php?t=157912&highlight=main+bolts
http://www.460ford.com/forum/showthread.php?t=155403&highlight=main+bolts
http://www.460ford.com/forum/showthread.php?t=154595&highlight=main+bolts
thanks , i would have always thought the studs would be the best for walk and strength
Saves you some money.......gotta talk to the professionals ( not me ) on this site and the 460ford site for the truth
I had a 4.5 inch eagle cast crank go south at around 700 HP. It started flexing at a little above 6000 rpm.
a 4.3 my be different it should have more overlap.
IDT-572 wrote:I had a 4.5 inch eagle cast crank go south at around 700 HP. It started flexing at a little above 6000 rpm.
I remember seeing the picture of that crank... was not pretty!
466cj- Posts : 391
Just to change the subject just a teeny bit ---- is Brian Adams back in business now. I know he had a terrible accident a few years ago, and was off the "radar screen" because of it. If you're back - I want to say welcome!! I bought a Scat stroker kit from you, and it's been perfect - THANKS !!
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
not everyone makes as much pah as the mothereffin' Snake..............
I'd think that 4.3 cast deal would be fine in this application..............but then again lol.
Wayne Pearce wrote:Just to change the subject just a teeny bit ---- is Brian Adams back in business now. I know he had a terrible accident a few years ago, and was off the "radar screen" because of it. If you're back - I want to say welcome!! I bought a Scat stroker kit from you, and it's been perfect - THANKS !!
AD never was out of busniess. My buddy Billy builds all his Motors and does all the machine work.
Hey, Dave:
Thanks for the response, that's good news as I had a very pleasant transaction experience with Brian when I bought my stroker kit. But a few years ago I sent him an e-mail, or a phone message (I'm suffering from "c.r.a.f.t."), and never got a response. I mentioned this on one of the forums, and somebody inferred that Brian was out of the business due to his accident. I'm very happy that it's not the case, again thanks for your response.
Last edited by Wayne Pearce on February 25th 2012, 11:07 am; edited 1 time in total (Reason for editing : spelling correction)
