Threw some scales under my turd............
Nice to have a friend of the familly who is a big baller roundy round guy, I got him to loan me his scales. Saves loading it up, burning fuel up to Mike's, 100 bucks an hour, fuel back...........you get the point lol.
I set the preload on the ladder bars neutral for a baseline. with my fat ass in the seat, both cells full, full NOS bottle, ready to go down the track she is 3048#'s. Front 55.9%, rear 44.1%
I lost about 15#s in the rearend upgrade, lost the primerplus cell, but gained another in front for the nos enrichment, added weight of a 7531 box......I figure its about the same as it was. Now add in the 40#'s of ballast it had in the trunk and the 25#'s of wheelie bars.............I had no idea it was that heavy and explains the reason it ran like it did ......hell I thought it was 60#'s light lol.
corner weights are off, but I have yet to set anything, I did take a bunch of preload out of the ladderbar on the right to get this baseline, so I doubt it was off much, it was wanting to go to the right pretty good so i know it wasn't right.
Just a little info, not much but what the hell..............
Re: Threw some scales under my turd............
Can't beat knowing where a baseline starting point is, makes it a lot easier to work back to it if needed. That and keeping logs of each change made from baseline & the results of said changes.
DILLIGASDAVE- Posts : 2262
jbozzelle- Posts : 3705
jbozzelle wrote:FAT
So that's a 2800 lb. car, because the driver is 200-250lbs.
even less you take that 40#'s of ballast out
res0rli9- BBF CONTRIBUTOR
No...it's 3200 lbs. dummy!!res0rli9 wrote:So that's a 2800 lb. car, because the driver is 200-250lbs.
56Tbird- BBF CONTRIBUTOR
As it sits right now with no ballast the car is 2845, I'm 200#'s...............cars don't go down a track with out a driver, anytime you refer to a cars weight I use the car and driver combined..............because without the driver it cant get down the track......simple fact.
without driver, if I put the 40#s of ballast back in it we ran with last year that puts the car at 2885, add 200 for the driver so it can go down the track and we get 3085.
Math is easy.
And that is basic math! Wake up Keith
you posted percentages. could you post actual numbers?
my wuss car goes like this> left rear 660, right rear 661, left front 990, right front 960 of course me sitting in it.
thanks bobn
thanks bobn
zbob- Posts : 271
I'll have to get the sheet...............she drove real good, I do need to take the lf spring down a turn though...............I sure woulda been lost without a baseline.
So ,did you make any passes this weekend??? Inquiring minds want to know
yep...............track was terrible, 60' was awesome, now if I can keep it from spinning through high gear I'll be...........
I may have to take it to a different track, one that cares about prep, thats all I'll say.
Its a mean bitch now..............
It'll be hard to get down any track right now with alot of power. you'll be good as soon as they get a few passes on the green surface.Green tracks and green oil just don't match up real good!!
yep only 3rd weekend open, just went to dust it off......I'll be ready for the 1st 5.30 race come April...........
Jon your turd is to heavy to run fast
or is it a runny turd
I did have to toss 30 back n the trunk, its 3078 now............with driver.
Well maybe when you get it on a good track it mite pass that Fart Mr Frosty is blowing
richter69 wrote:...........now if I can keep it from spinning through high gear.........
Maybe it's time to start thinking about a small/medium sized deck wing.
a very good possibility, I've already considered it.
richter69 wrote:a very good possibility, I've already considered it.
They work.............
yeah yeah I'll get the fab skills in effect...........again lol.
What ET/MPH did it turn?
some numbers in the DD thread
damn, gonna make me go look over there...LOL
ok I got some ideas for a wing, will get some measurments tonight and get started on it.
» New look for the old turd......
» Using scales to adjust ladder bars ?
» Small block turd.........*In car video*
» WTB car scales
» Scales ?????
» WTB car scales
» Scales ?????
