DRY VS WET SUMP
DRY VS WET SUMP
WET OR DRY SUMP?
DOES ANY ONE HAVE A IDEA OF WHAT THE HP DIFFERENCE SHOULD ON A 600" A460 MOTOR
AND HOW MUCH WEIGHT WILL THIS ADD?
AND THE DIFFERENCE IN COST?
THANKS LOGAN FROM N.C.
fastford600- Posts : 391
Re: DRY VS WET SUMP
fastford600 wrote:WET OR DRY SUMP?
Dunno bout this one
fastford600 wrote:AND HOW MUCH WEIGHT WILL THIS ADD?
Been a while since I've held a dry sump(4 stage) but with all the trimmings probably just a few pounds more, I'm not sure the pump itself maybe a little heavier than a Kaase wetsump which is a meaty piece of cast iron. Difference is probably in all the other junk that you need with the pump. Maybe 15 or so pounds.
fastford600 wrote:AND THE DIFFERENCE IN COST?
Significantly higher with the dry sump.
Declawed69- Posts : 19
Re: DRY VS WET SUMP
thanks
» Front sump vs rear sump
» Switching from dry sump to wet sump.....
» Oil Pan Sump Mod
» Dry Sump Pan
» wet sump vs dry sump
» Oil Pan Sump Mod
» Dry Sump Pan
