Hp guesses
Hp guesses
14:1 557 cast crank scat procomp I beams probe flat tops. Ford racing scjb heads, awaiting Kaase spec'd solid roller .660~ lift, Vic 460 port matched quickfuel 4150 e85 1050. 2 1/8 primary headers. What should I be looking for at flywheel?
Onequickfiveoh- Posts : 26
Re: Hp guesses
Ots heads, intake basically gasket matched.
Re: Hp guesses
More cam specs would help us guess, .660 is not much lift for a Ford Solid roller. But the good thing is the SCJ's peak flow at .570 to .590 lift.
Give use some @ .050 numbers and intake and exhaust center line numbers (Separation)
If the cam is up to task it could make over 750 hp. But with out a dominator carb it will be harder.
Re: Hp guesses
Cam hasn't been ordered yet. Some what of a budget build. Sticking with the springs that came on the heads with Kaase specing the duration lsa and valve events
Re: Hp guesses
The class I want to make a few passes in is a 4150 only class.
» Any guesses?
» ANY HP/TQ GUESSES,IDEA ???/
» Carb changes any guesses
» Horsepower guesses
» Mild (less than ideal) 466 chassis dyno results, guesses for conversion to flywheel horspower
