DRY SUMP OIL SYSTEM
DRY SUMP OIL SYSTEM
What systems are you guy's running?
LEM!! You had one on your boat!!
dust the dirt off it and SELL it to me!!! NOW!!!!
blown86hallet- Posts : 1012
Re: DRY SUMP OIL SYSTEM
blown86hallet wrote:What systems are you guy's running?
Adam, It was a Peterson pump.
Moroso 4 stage pump with a custom pan and tank.
It is really good to have a tank with a removable top to ease cleaning.
The next pump will most likely be a Peterson, but I also like Weaver for thier durability and great customer service.
Keith
Keith
Dont know about the weaver but my peterson pump only has one line back to the tank. Internal manifold on the discharge side as opposed to seperate return for each stage. Less lines, less fittings.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
bosshoss wrote:Dont know about the weaver but my peterson pump only has one line back to the tank. Internal manifold on the discharge side as opposed to seperate return for each stage. Less lines, less fittings.
dkp
Oh...yeah...that is a great feature. The new Moroso pumps have that design and Weaver is also offering them.
My older Moroso pump uses a $$ external manifold to make the single #16 scavenge return.
After installing a couple of Petersons on customer engines recently, I am leaning that way. They look and feel great.
Keith
» Front sump vs rear sump
» Switching from dry sump to wet sump.....
» BBF dry sump pan
» auc u sump
» Oil Pan Sump Mod
» BBF dry sump pan
» auc u sump
» Oil Pan Sump Mod
