max vac on dry sump?
max vac on dry sump? Empty max vac on dry sump?
Post  fastford600 September 21st 2009, 9:19 pm
how much vac can you run on a 600" bbf i was told that if pull over 17in lbs of vac that it would pull oil away from the wrist pins
fastford600
fastford600
max vac on dry sump? Empty Re: max vac on dry sump?
Post  richter69 September 21st 2009, 9:21 pm
We did 16" on our smallblock with no issues, 12" would be pretty safe IMO.
Post  fastford600 September 21st 2009, 9:33 pm
thanks is it the same on a bbf? alien
fastford600
fastford600
Post  David Willingham September 22nd 2009, 9:11 am
What is your pin clearance? I had mine opened up to .0015-.002" because I'm going to run a Peterson 5-stage with a Star Machine vacuum pump.
David Willingham
David Willingham
Post  Lem Evans September 22nd 2009, 10:26 am
fastford600 wrote:how much vac can you run on a 600" bbf i was told that if pull over 17in lbs of vac that it would pull oil away from the wrist pins
16" should be plenty . With a 600" engine you;ll have to have a vac. pump also to get that much unless you have a super high dollar pump .
max vac on dry sump? Empty Vacuum
Post  Wheelie58 September 22nd 2009, 4:53 pm
I hve been running up to 17 inches on my 605 with a dry sump with no issues.
I have a 3 stage Moroso pump, running at 50% and a Moroso enhanced design vacuum pump running at about 65%.
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
