dry sump / wet sump ?
dry sump / wet sump ? Empty dry sump / wet sump ?
Post  bruno September 12th 2011, 8:41 pm
what is the differnce in weight between the 2 systems ?
http://WWW.CKRME.COM
dry sump / wet sump ? Empty Re: dry sump / wet sump ?
Post  Curt September 12th 2011, 8:42 pm
How many stages?
Post  bruno September 12th 2011, 8:45 pm
i would like to do a 5 stage with my hp goals
Post  Curt September 12th 2011, 8:48 pm
bruno wrote:i would like to do a 5 stage with my hp goals
No need for a dry sump for 335hp Razz
Post  cool40 September 12th 2011, 9:16 pm
i think i've read 35lbs. somewhere. the tank,lines,and more oil. i thought about it for mine but i just dont see it in a 1/8 mile car like mine.little extra weight is fo sho the only con.does the dry sump need a vac pump?
Post  bruno September 12th 2011, 9:20 pm
cool40 wrote:i think i've read 35lbs. somewhere. the tank,lines,and more oil. i thought about it for mine but i just dont see it in a 1/8 mile car like mine.little extra weight is fo sho the only con.does the dry sump need a vac pump?
so you are doing a wet sump on the 605 ?
Post  Curt September 12th 2011, 9:24 pm
Yeah, about 35 pounds on mine.
Post  bruno September 12th 2011, 9:25 pm
Curt wrote:Yeah, about 35 pounds on mine.
how many quarts of oil smart azz , oops i mean Mr. smart azz Surprised
Post  Curt September 12th 2011, 9:29 pm
My does the same 9 quarts my wet sump used rabbit
Post  cool40 September 12th 2011, 9:34 pm
yep. got my new "Baller series" pan today.dry sump / wet sump ? Oil_pa11
Post  cool40 September 12th 2011, 9:36 pm
Curt wrote:My does the same 9 quarts my wet sump used rabbit
what about a vac pump Curt? you run one or does it need it?
Post  whatbumper September 12th 2011, 9:42 pm
I know we are not up there with your cubic inches but our little sb turd is wet sump with a peterson external pump and a vacuum pump.
Post  Curt September 12th 2011, 9:49 pm
I'm not running one. When Bob dyno'd it, he didn't seal off the breathers and it still pulled vacuum, so I'm thinking it will do quite well with the sealed valve covers.
Post  cool40 September 12th 2011, 10:04 pm
i was'nt sure,i've never ran a drysump.if you dont need a vac pump with a drysump then thats a plus on weight and $$ too.another + for the drysump.
Post  cool40 September 12th 2011, 10:05 pm
whatbumper wrote:I know we are not up there with your cubic inches but our little sb turd is wet sump with a peterson external pump and a vacuum pump.
i think Fabio has that setup too,also a good idea.
Post  Curt September 12th 2011, 10:28 pm
Bob did a great job shoe horning. It was a tight fit, and he sized it up from 800 miles away.
dry sump / wet sump ? Newbuild39
Post  Lem Evans September 12th 2011, 10:48 pm
K.Y. , green oil and methanol approved.
Post  David Willingham September 13th 2011, 9:02 am
My 641 made 7" at idle, 1-2" at 7500 on methanol with only the drysump. When we hooked up the dyno room vacuum pump, it went to 21" at idle and 18" at 7500. It picked up 18 hp. I will also say that my engine made 1134 hp the day before with no vacuum because of a severe leak. We tracked down the leak, fixed it and started the engine. Vacuum came up to 7" at idle. On the first hit that day with no other changes, it made 1160 hp. So it was either sealed up better after the first day of running or the drysump pulling that little bit of vacuum helped it. I don't know. Probably a little of both.
David Willingham
David Willingham
