TEA Trickflow cnc ported 325cc 460 head flow #s
TEA Trickflow cnc ported 325cc 460 head flow #s Empty TEA Trickflow cnc ported 325cc 460 head flow #s
Post  10SHOTS March 15th 2012, 12:07 pm
Just got off the phone with TEA , they gave me some flow numbers using a 4.500 bore and a 5 angle valve job
he said trickflow ports there own heads not tea. do you guys think these heads can flow these numbers? also listed tfs numbers and tea small bore
tea 4.500 bore -------- tea 4.380 bore -------trickflow 4.625 bore 3 angle valve job
.100 80 / 66 ----------- 77.6 / 57.9---------- 81 / 58
.200 161 / 127---------- 138.1 / 117-----------162 / 115
.300 250 / 175---------- 211 / 158.2-------- 262 / 160
.400 320 / 215---------- 287.9 / 199.3-------- 332 / 196
.500 370 / 245---------- 343.3 / 236.7-------- 370 / 223
.600 400 / 271---------- 369.5 / 259.9-------- 388 / 261
.700 407 / 275---------- 386.8 / 275.8-------- 401 / 290
.800 414 / 280---------- 394.4 / 287.3-------- 408 / 302
10SHOTS
10SHOTS
TEA Trickflow cnc ported 325cc 460 head flow #s Empty Re: TEA Trickflow cnc ported 325cc 460 head flow #s
Post  rmcomprandy March 15th 2012, 1:58 pm
10SHOTS wrote:Just got off the phone with TEA , they gave me some flow numbers using a 4.500 bore and a 5 angle valve job
tea 4.500 bore tea 4.380 bore trickflow 4.625 bore 3 angle valve job
Trick Flow and TEA are part of the same company.
Post  10SHOTS March 15th 2012, 2:42 pm
The guy at tea said he does some hand blending an a 5 angle valve job where as trickflow does not . this is just what he said . im just wondering if the head will flow those numbers on a 4.500 bore
10SHOTS
10SHOTS
Post  IDT-572 March 15th 2012, 5:47 pm
I had some ports on the proto type head right at 400 cfm. I think with the chamber work that Tooley did, the 408 number probably is correct.
I had rather have the extra compression and forgo the extra flow, unless I was on the hose.
TEA's bench is very Liberal. TFS's bench is a good number.
I also had an exhaust port on that head go 281 cfm, we were just trying to find two good intake ports and one exhaust to digitize.
I have been waiting to see someone buy a set of those heads and post some dyno numbers.
I ran a 5.67 with those proto type heads in my 86 notch at 3100 lb.
Post  rmcomprandy March 15th 2012, 7:13 pm
IDT-572 wrote:I had some ports on the proto type head right at 400 cfm. I think with the chamber work that Tooley did, the 408 number probably is correct.
Brian Tooley is no longer associated with TEA. He sold his interest in that company to Trick Flow who is in turn owned by the same people who own Summit.
