oil temp
oil temp Empty oil temp
Post  FORDMUD March 26th 2012, 10:44 pm
Besides the oil pan, where can I put a sender for oil temp? I don't want to pull the engine and pan. Would a drain plug adapter deal work? What's a good temp to shoot for before a 200' mud run? 528 steel rod, iron head 20/50 oil.
FORDMUD
FORDMUD
oil temp Empty Re: oil temp
Post  bosshoss March 26th 2012, 11:29 pm
I drilled a pan plug for a temp probe before. worked good till the next time I had the pan off.
dkp
bosshoss
bosshoss
Post  cooter March 27th 2012, 10:11 pm
i have put a probe in the drain plug and thought it worked well. Temperatures between 160 to 180 should be in the desired range.
cooter
Post  LivermoreDave March 27th 2012, 10:37 pm
http://www.elephantracing.com/techtopic/oiltemperature.htm
LivermoreDave
