crank shaft
crank shaft Empty crank shaft
Post  wayne w March 27th 2012, 9:47 am
I have a 69 460 block it has a external balancer behind the cast pulley cant find any water pump pulleys or brackets to fit it can i change the crank shaft to a newer style crankshaft without the balancer or can i change just the dampener to one that takes bolt on pullrys
wayne w
