CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE
bosshoss
10SHOTS
CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE Empty CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE
Post  10SHOTS April 1st 2012, 11:12 pm
I was checking the crank thrust today on my a-460 block and eagle crank today and noticed the crank rubs the main saddle and cap on #4 main front of block side What the hell.has any one else seen this? whats the fix, mill the cap? grind the block? defective? normal?
10SHOTS
10SHOTS
CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE Empty Re: CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE
Post  bosshoss April 2nd 2012, 12:52 am
Had the same problem with a Scat 4.5 crank in an A460 block. Had to do a bit of grinding on the block.
dkp
bosshoss
bosshoss
Post  DanH April 2nd 2012, 2:17 am
early Scat cranks had a wider space between the counter weights for # 2 and 4 mains , fit OK. late Sact crank is different , narrower in that area .
caps won't be even with the block , have a overhang either to front or rear . lucky if you get a block with no overhang
DanH
Post  bruno April 2nd 2012, 7:27 am
i believ my rpm deal was the same issue
http://WWW.CKRME.COM
CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE Empty crank or block
Post  10SHOTS April 2nd 2012, 9:28 am
so is it the crank or the block causing the issues? or both lol
10SHOTS
10SHOTS
Post  dfree383 April 2nd 2012, 9:32 am
The Crank, I have not had issues with my Bryant or my Scat ones.
CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE Empty crank rubs
Post  10SHOTS April 2nd 2012, 9:59 am
so do i work on the block or get a new crank and try it again
10SHOTS
10SHOTS
Post  DanH April 2nd 2012, 10:39 am
10SHOTS wrote:so do i work on the block or get a new crank and try it again
work the block
DanH
Post  Paul Kane April 2nd 2012, 2:27 pm
10SHOTS wrote:so is it the crank or the block causing the issues? or both lol
I don't think it should be look at that way. Simply put, this is an accepted part of custom engine building. You are not building a "plug-and-play" engine, you are setting up the fine details of the combniation as it best suits your speicific build.
Paul
CRANK SHAFT RUBS A-460 BLOCK MAIN SADDLE Empty fixed
Post  10SHOTS April 2nd 2012, 2:42 pm
machined the block,fixed now
10SHOTS
10SHOTS
Post  bosshoss April 2nd 2012, 2:47 pm
Has the crank been balanced yet?
dkp
bosshoss
bosshoss
Post  10SHOTS April 2nd 2012, 2:50 pm
bosshoss wrote:Has the crank been balanced yet?
dkp
no why? just laid the crank in the block and spun it to see what all needed to be ground on
10SHOTS
10SHOTS
Post  bosshoss April 2nd 2012, 8:36 pm
Any material you remove from the crank will affect the balance situation. If it had already been done then you have to check it again after removing material.
dkp
bosshoss
bosshoss
