first bbf build
first bbf build
i am starting a 521 build,i am thinking of useing the scat 4.3 stroke 4340 crank,and 6.8" rods with the arp 2000 bolts and maybe some diamond pistons with the p-51 heads.any advise and suggestions would be appreciated.
billybob325- Posts : 10
Re: first bbf build
same rotating assy and heads here, runs pretty good I rekon..............
Re: first bbf build
Had one built about 2 years ago run 560's N/A all day long.Out box heads and intake no port work. The car matter must state it was backhalf car.
bigjohn2007- BBF CONTRIBUTOR
Re: first bbf build
we are talking about putting it in a 65 mustang stock suspension.what did your car weigh?sure is a long lead time on the heads,are they sticking to their 6 to 8 week estimate?bigjohn2007 wrote:Had one built about 2 years ago run 560's N/A all day long.Out box heads and intake no port work. The car matter must state it was backhalf car.
Re: first bbf build
billybob325 wrote:we are talking about putting it in a 65 mustang stock suspension.what did your car weigh?sure is a long lead time on the heads,are they sticking to their 6 to 8 week estimate?bigjohn2007 wrote:Had one built about 2 years ago run 560's N/A all day long.Out box heads and intake no port work. The car matter must state it was backhalf car.
Better do some measuring as a BBF not going to fit in a 65 Mustang without some cutting.
466cj- Posts : 391
Re: first bbf build
yea,we are going to use a rack and pinion and cross member setup.going to cut the shock towers
out and notch the firewall a bit.
Re: first bbf build
billybob325 wrote:i am starting a 521 build,i am thinking of useing the scat 4.3 stroke 4340 crank,and 6.8" rods with the arp 2000 bolts and maybe some diamond pistons with the p-51 heads.any advise and suggestions would be appreciated.
Id get with Lem Evans here on the forum and get a "Mafia" intake, a Charlie's oil pan, and a Camshaft from him.............He's also a Diamond dealer............
Re: first bbf build
sounds good.richter69 wrote:billybob325 wrote:i am starting a 521 build,i am thinking of useing the scat 4.3 stroke 4340 crank,and 6.8" rods with the arp 2000 bolts and maybe some diamond pistons with the p-51 heads.any advise and suggestions would be appreciated.
Re: first bbf build
http://bfevansraceparts.com/default.aspx
Re: first bbf build
2950 W/D
Re: first bbf build
going to try and keep the mustang to 3000,that want work to well when i am driving though i out weigh the owner by about 140 pounds.bigjohn2007 wrote:2950 W/D
Re: first bbf build
well we decided to go with a 67 mustang,found one for 1500.the car is in pretty good shape.so that put him a little behind on cash for the heads,but we will be getting the p-51 heads.soon i hope i am ready to get back on the build.
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» 460 build w/p51 heads build HELP!!
