cutting c4 bellhousing
johndickjr
cutting c4 bellhousing Empty cutting c4 bellhousing
Post  johndickjr March 28th 2012, 9:00 pm
would it hurt the bell housing if i cut a small part out of the bell housing on the bottom side..just enough to get a wrench on the back side of the flywheel to hold a nut...the converter i bought has stripped holes..even new it had only about 3 threads(BTE) converter..so i had to drill some holes and move them out and use a nut..but have no way to tighten them up...or option number 2 i can have a stud welded on..
johndickjr
cutting c4 bellhousing Empty Re: cutting c4 bellhousing
Post  richter69 March 28th 2012, 9:35 pm
The JW ultrabells are open at the bottom, but they are a lot thicker also. I dont know if it would hurt it, if anything use a holesaw...the smallest one possible.
Post  johndickjr March 28th 2012, 9:46 pm
richter69 wrote:The JW ultrabells are open at the bottom, but they are a lot thicker also. I dont know if it would hurt it, if anything use a holesaw...the smallest one possible.
i will try that..
johndickjr
Post  cool40 March 28th 2012, 9:58 pm
i always work through the starter hole if i had to.
Post  johndickjr March 28th 2012, 10:00 pm
cool40 wrote:i always work through the starter hole if i had to.
tired that..cant get a wrench in there...guess i could bend it 90 degrees
johndickjr
Post  cool40 March 28th 2012, 10:43 pm
yep,done that too and cut one of the gooseneck boxed end deals in half.are they 7/16?if not then drill and tap to 7/16 and open up the holes in the plate.i've had converters with nuts welded on the backside too.
Post  johndickjr March 28th 2012, 10:45 pm
just talked to a buddy..said he can weld a stud or weld a nut on the back side..either one will work..i guess..lol
johndickjr
Post  cool40 March 28th 2012, 10:48 pm
if its out then go for it.i'd tac a nut on it,the stud may not like welding,JMO.bolt the nuts down so they'll be in place. Wink
Post  richter69 March 28th 2012, 11:08 pm
most converters have the bolts welded or tacked on the backside, or use studs. This and not cutting the bell would be best IMO.
Post  powerstrokeace April 15th 2012, 11:13 am
I've never seen a FORD converter that didn't have studs for the mounting points on the converter. I'd say you have something wrong just to start..
Ace
powerstrokeace
powerstrokeace
Post  Frank Merkl April 15th 2012, 6:11 pm
drill a hole in the bottom with a hole saw won't hurt a thing
Post  johndickjr April 15th 2012, 6:33 pm
powerstrokeace wrote:I've never seen a FORD converter that didn't have studs for the mounting points on the converter. I'd say you have something wrong just to start..
Ace
all converters i have ever seen that had any stall to it had no stud but a nut..i end up having a nut welded on it..
johndickjr
Post  Frank Merkl April 15th 2012, 9:36 pm
I lock nut them all an the back side and after tire shake they still will come loose!
Post  whitefield April 16th 2012, 9:18 am
Frank Merkl wrote:drill a hole in the bottom with a hole saw won't hurt a thing
Only if you have too ! X2 with what Frank said
whitefield
whitefield
