6 oh blues
6 oh blues Empty 6 oh blues
Post  scottke April 1st 2012, 9:58 pm
Well I guess my luck has run out. The 6.0 in the SD is giving me it's first trouble since I bought it 4 years ago. Got in it to go to Lowes sat morning and it was idling rough. Turned around to go back home and it got worse. Guess the engine went into default. Would barely pull it's self from a stop.
Got in it last night to try to take it to the shop I use and WOW it ran perfect for a few minutes, but it did it again. By the time I got it to the shop it was running rough again.
SUCKS!!!!! scratch Evil or Very Mad Crying or Very sad
scottke
scottke
6 oh blues Empty Re: 6 oh blues
Post  richter69 April 1st 2012, 10:22 pm
sounds like the FICM took a shit....................very common. Or it could have an injector issue, I've seen clogged fuel filters starve the injectors and it takes the return spring out in the tip allowing combustion gas to get into the fuel system and do as you describe.
Post  scottke April 1st 2012, 10:28 pm
Its been a really good truck so far. Hope its a easy fix.
scottke
scottke
Post  richter69 April 1st 2012, 10:31 pm
easy yes, cheap.......................depends what you consider cheap. You pop the hood for any reason and its 500 bucks...............
Post  scottke April 1st 2012, 10:33 pm
Like I said........SUCKS ASS.
Got race car parts to buy, not truck parts. LOL!!
scottke
scottke
Post  richter69 April 1st 2012, 10:40 pm
[quote="scottke"]Like I said........SUCKS ASS.
exactly, thats why I drive an old pos 99 lol.
Post  scottke April 1st 2012, 10:59 pm
7.3 is sounding good right now.
Guess I'll just hope for the best.
scottke
scottke
Post  richter69 April 1st 2012, 11:09 pm
anything I can help with let me know.
Post  scottke April 2nd 2012, 8:18 am
Thanks, I appreciate it.
scottke
scottke
Post  John I. April 2nd 2012, 2:26 pm
If you have a multimeter, you can test it yourself in a few minutes. Unbolt the degas tank and move it to the side, take the 2 torx screws out of the plate on top of the ficm, remove it and test the voltage at the screw closest to the drives side fender. (This is assuming you have a 4 screw ficm, not a 7) Test it koeo, cranking, and running. It should be between 46 48 volts. If it's toast, you can have it repaired for about 300 bucks compared to being charged over 1000 at a dealership for a new one. Ed at FICMrepair.com can do them in a day.
Also could be the egr valve sticking, not hard to pull it out and have a look/clean it, although if it's sticking it should set a code. Not trying to undermine Jon here, just some simple(free) stuff you could try first.
John I.
Post  scottke April 2nd 2012, 2:51 pm
Lookin like good news. Shop says looks like some trash in the fuel. Been drivin it and is only idling a little rough. Says runs fine on the road.
scottke
scottke
Post  richter69 April 2nd 2012, 3:11 pm
How did they figure this out and what repairs made? I have my doubts this was all that was wrong or that its completely fixed........ Keep an eye on it.
Post  scottke April 2nd 2012, 10:25 pm
Left the shop with it and it still ran like shit. Stopped to put more good fuel in it. Headed for home and kept running rough, finally just died. Wouldn't restart, sat for about 5 minutes then it fired right up and ran 95% better. Got to the house with no problem. Just a hint of a rough idle....?????????????????????? Rolling Eyes
scottke
scottke
Post  richter69 April 2nd 2012, 10:50 pm
its not fixed..............if the lower fuel filter was plugged bad enough it starved the injs for fuel you have a broke return spring in an injector................or the fuel filter cap on the pump was not fully seated, look and make sure there is no gap between the filter cap and the housing. If its fully seated, the next time it quits running shut the key off and pull it from the ign, then go take the small filter loose from the front of the engine..........if that housing is not full of fuel an injector is damaged as I described. If its full then you could have a FICM voltage issue, in which we replace with half shell's due to the lesser cost to the customer..unless its an 03 that has the 7 bolt units, they have to have the whole thing replaced and reprogrammed.
Not slammin the shop but "junk in the fuel" short of gasoline or water contamination is no reason for it to run like you describe. I get them towed in all the time from other shops that have no clue.
side not, if there is black smoke coming from the tailpipe its usually FICM related, white smoke can be egr or a broked injector tip return spring broken as I described.
Post  scottke April 2nd 2012, 11:58 pm
There is black smoke comin out, but mainly justwhen I shower down on it.
scottke
scottke
Post  richter69 April 3rd 2012, 8:35 am
if its chipped up that could make the black smoke, I have just noticed when the FICM voltage gets low enough to make the truck run bad they will also create black smoke.
Post  richter69 April 9th 2012, 11:00 am
I saw in the other thread you had the truck back in the shop, any updates?
Post  scottke April 9th 2012, 11:55 pm
Not working on it till tomorrow. Hoping for the best. LOL
His snap-on scan tool showed #5 injector bad.
Voltage on the FICM was 48.
scottke
scottke
Post  scottke April 15th 2012, 8:09 pm
Gotter back Friday! #5 injector had a cracked tip.
Running great once again! Cool
scottke
scottke
Post  cool40 April 15th 2012, 8:38 pm
Very Happy
Post  scottke April 15th 2012, 9:17 pm
Going to the Bend next Sat. to finally do some testing! whoooohoooo!!
scottke
scottke
Post  richter69 April 15th 2012, 11:21 pm
scottke wrote:Gotter back Friday! #5 injector had a cracked tip.
keep them fuel filters changed every 20k............. Wink
Post  scottke April 15th 2012, 11:57 pm
For sure. Thanks for the input!
scottke
scottke
Post  yellowhorse7 April 16th 2012, 9:06 am
scottke wrote:For sure. Thanks for the input!
Fwiw I change both and every oil change on my 2006. Overkill I suppose but I ain't taking no chances
yellowhorse7
yellowhorse7
Post  richter69 April 16th 2012, 11:36 am
I take off 2 days and come back to a pile of broke 6.0's....................life is good. Smile
