Synthetic oil
+9
342g
Barney
Danny Cabral
LivermoreDave
cooter
NO FAIR
13 posters
Synthetic oil
What are you guy's using? Royal purple, AMS, Red line who makes the best?
Dave
Dave
NO FAIR- Posts : 138
Re: Synthetic oil
i use valvoline and amsoil
cooter- Posts : 220
Re: Synthetic oil
ive been running the vr1 , ive now switched to royal purple xrp
Re: Synthetic oil
I used Mobil1 for years in most of my vehicles, including the race stuff. I have switched to Kendall full synthetic in the last four to five years simply due to cost. Either oil seems to give excellent performance. The Mobil1 continues to be used in my motorcycle, no issues there either. One thing I have found useful, if not mechanically, for sure mentally, the use of COMP's oil additive. The additive is included in the race stuff when each engine is serviced. The drained oil with additive from the race engines then becomes available to the mowers, riders and pushers!
For a power increase, I noticed posted on another website, some of the race oils such as Royal Purple consistently showed power improvements on the dyno.
Dave.
Dave.
LivermoreDave- Posts : 972
Re: Synthetic oil
I use Mobil 1 synthetic 15W-50.
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Zinc_Levels_15W50_Mobil_1_Products.aspx
It's also very good for flat tappet camshafts:
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Zinc_Motor_Oils.aspx
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf
Danny Cabral- Posts : 14
Re: Synthetic oil
Re: Synthetic oil
Barney wrote:Brad Penn
X2
342g- BBF CONTRIBUTOR
Re: Synthetic oil
X3 Thx to HaroldBarney wrote:Brad Penn
Re: Synthetic oil
Not all engine lubricants sold as synthetic are the same. We can all tell our favorites, but generally speaking, you do get what you pay for in sythetic lubricants. Personally, I like to stick around Amsoil, Mobil 1, Royal Purple, and Red Line. Note that if you don't take advantage of the extended drain intervals, or your engine leaks profusely, or consumes a lot of oil, then the overall cost may be higher. If you take advantage of the extended drain intervals and your engine holds oil then the price is not only well worth it but the extended life of the engine makes the use of a good synthectic a better deal in the long run. Many people register more horsepower on the dyno when they switch to a quality synthetic. The old belief that synthetic oil leaks is a bunch of hogwash; if you engine leaks oil then the engine has a leak....fix the leak.NO FAIR wrote:What are you guy's using? Royal purple, AMS, Red line who makes the best?
Dave
Paul
Re: Synthetic oil
After a bunch of discussion with several people, I'm going to make the switch and give the Brad Penn stuff a try. Keep hearing all the talk about the "green oil" so I gotta see for myself!
kjett- Posts : 1169
Re: Synthetic oil
Klutz lubricants has some pretty interesting stuff also, but it is PRICEY and I'm not familiar with it personally.
Re: Synthetic oil
Kinda partial to Amsoil. They are a major sponsor of the IHRA this year.
Even if you want to try a different oil take a look at the filters. They are very well designed.
whatbumper- Posts : 3024
Re: Synthetic oil
I like Amsoil, Redline and Royal Purple.
I have seen Scheaffer products used before too.
Re: Synthetic oil
i dont run it maybe i should try some! how much will it pick me up? i need some help for this june race
Re: Synthetic oil
depends on the combo and what your running now..... can be upwards of 15-20hp on some applications.
Re: Synthetic oil
Paul Kane wrote:Not all engine lubricants sold as synthetic are the same. We can all tell our favorites, but generally speaking, you do get what you pay for in sythetic lubricants. Personally, I like to stick around Amsoil, Mobil 1, Royal Purple, and Red Line. Note that if you don't take advantage of the extended drain intervals, or your engine leaks profusely, or consumes a lot of oil, then the overall cost may be higher. If you take advantage of the extended drain intervals and your engine holds oil then the price is not only well worth it but the extended life of the engine makes the use of a good synthectic a better deal in the long run. Many people register more horsepower on the dyno when they switch to a quality synthetic. The old belief that synthetic oil leaks is a bunch of hogwash; if you engine leaks oil then the engine has a leak....fix the leak.NO FAIR wrote:What are you guy's using? Royal purple, AMS, Red line who makes the best?
Dave
Paul
I have heard the same thing about motors leaking more with synthetic oil but I guess I figured if that is the case the motor was going to leak anyways no matter what you put in it.
Dave
Re: Synthetic oil
when synthetic oil first cam along my uncle was a dealer for some,off brand used by the company he worked for.my dad had a new crown vic,4.6 with 20-30k on it.he put the synthetic oil in it and it started to leak in the garage floor after a few hundred miles.he also put it in his lawn mower,it leaked too. he went back to his old oil in both and the leaking stopped.i used mobil1 in my 86gt and it never leaked! so.........could it be the oil? the 4.6 did use the 5-20 stuff?
