Synthetic oil 20w-50
Synthetic oil 20w-50 Empty Synthetic oil 20w-50
Post  Dave De December 17th 2022, 5:20 pm
Like everything else in this world becoming an ordeal to get. Mobil 1 20w-50 is no longer available unless you buy the motorcycle V twin version by the quart. So I'm looking for another brand. I cant use Brad Penn because I'm running E85.
Any suggestions? Its got to be synthetic because the by-products of alcohol can be acidic.
Synthetic oil 20w-50 Empty Re: Synthetic oil 20w-50
Post  Lem Evans December 17th 2022, 10:04 pm
Dave De wrote:Like everything else in this world becoming an ordeal to get. Mobil 1 20w-50 is no longer available unless you buy the motorcycle V twin version by the quart. So I'm looking for another brand. I cant use Brad Penn because I'm running E85.
Many moons ago Mobile 1 had a 15w 50
Post  Dave De December 17th 2022, 10:14 pm
After I posted this I found that 15w-50 is available and at Walmart. I will do that. Thanks-Lem
Post  rmcomprandy December 17th 2022, 10:20 pm
I will recommend AmsOil ... they have a few different grade oils which are 20W-50. Their "Premium Protection" synthetic is the best I have found in that weight, especially when anti-foaming is needed.
Their "Dominator" racing oil is great for racing only engines and their "Signature Series" oils are for longer drain times but, are only available in lighter weights..
I have used them all for the correct situation.
Post  650jetmech December 18th 2022, 11:30 am
I only run Joe Gibbs Driven oil in anything that I care about. I’ve even had very good luck with their tech line.
650jetmech
Post  dfree383 December 19th 2022, 7:43 am
Amsoil or redline
Post  Uglytruck December 19th 2022, 11:40 am
X2 on the Amsoii. Great stuff, I've run it in my vehicles and race truck for years.
Uglytruck
Post  69F100 December 20th 2022, 4:08 pm
I run Kendell 20w50 racing oil I also run methanal not e85 but I don't have any problems with it I also run it in my 69F100 it has zinc in it also
Post  Dave De December 21st 2022, 8:37 pm
I looked into AmsOil and dont like the cost. I will stick with Mobil 1 15w-50. Combustion byproducts from E85 make synthetic the best choice. I might stock up on 15w-50 because it will be gone in a few years as well.
Thank you all for your recommendations.
Lem Evans and dfree383 like this post
