BB Fox Power Steering
BB Fox Power Steering Empty BB Fox Power Steering
Post  zwoodhead April 12th 2012, 3:41 pm
Hey guys just had a question. I'm putting a BB in my 1992 fox lx 2.3l, but haven't started the swap quit yet. I'm trying to decide what kind of steering to go with. Iv got a new tubualar K member going in it so I was just going to put the stock rack back on the K member. My question is, if I want to keep my power steering, can I just use the stock rack and pinion?? Is there a way to get the BB power steering pump to hook up to the stock 1992 rack and pinion system?? Any info helps. Thanks.
zwoodhead
BB Fox Power Steering Empty Re: BB Fox Power Steering
Post  Mark Miller April 12th 2012, 11:42 pm
I used the power steering pump from the 4 cylinder on my 89 Mustang and had brackets made to bolt it to the 460.I always had belt slippage problems though.I then changed to a manual rack because the power steering rack was leaking.I also used the stock 4 cylinder alternator with stock 75 Lincoln brackets and spacers made by a friend.I modified a 88 T-Bird 3.8 waterpump pulley to work on the 460 waterpump and used a 87-93 5.0 Mustang crank pulley.
Later Mark.
Post  Mike R April 13th 2012, 6:23 pm
If you decide to go with a manual rack there's a smokin deal here $175.00 delivered is CHEAP!!! http://www.ebay.com/itm/Flaming-River-1979-1993-Mustang-Manual-Steering-Rack-/270953092775?fits=Model:Mustang&hash=item3f161016a7&item=270953092775&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
BB Fox Power Steering Empty BB with power steering
Post  bigdaddy198 April 13th 2012, 9:46 pm
I have a 82 foxbody with a 460 and i am running a stock 460 steering pump to my connections on the rack steers with 1 finger but feels a little to easy guess i just gotta get used to it but steers very easy Suspect
bigdaddy198
Post  bigblok2000ranger August 15th 2012, 11:22 pm
1984 up truck with 460 has the same pump as the foxbody but in big block brackets. I had the complete pulley setup on my mustang.
bigblok2000ranger
bigblok2000ranger
