wheel speed
wheel speed
i am using a 10'5 tire 29.5 tall on a 10 inch rim @ 12 lbs pressure. which way should I go with pressure to increase wheel speed? The car almost dead hooks now, maybe 1/4 turn on launch.
Launch rpm is close to 4500
Larry Williams- Posts : 884
Re: wheel speed
i would say that increasing pressure would cause more wheel speed ....but why dont you increase your launch rpm ? what convertor do you have ? what type of rear suspension ?
Re: wheel speed
bruno wrote:but why dont you increase your launch rpm ? what convertor do you have ? what type of rear suspension ?
X2
yellowhorse7- Posts : 1382
Re: wheel speed
bruno wrote:i would say that increasing pressure would cause more wheel speed ....but why dont you increase your launch rpm ? what convertor do you have ? what type of rear suspension ?
its a stock type fox body suspension with good componants. I did try a 5500 rpm converter last year ( it was a very short season for me ) but the car lost 10 mph at the 1/4 so I went back to my previous converter
in the avitar it went a 1:31 60 foot 20 feet from the starting line the wheels were still in the air in the avitar
Re: wheel speed
You can try higher psi but I'd bet that will only act as a band aid. My guy tells me tha the anti squat is off and the IC is too short...
» What gears?
» Need help swapping a Q-Stick shifter from 3 speed to a 2 speed...
» Liberty 3 speed or 4 speed
» JW "The Wheel" External balance flex plate(SOLD)
» Which ARP flexplate bolts do I need?
