Aluminum Radiator
kjett
77f150
Aluminum Radiator Empty Aluminum Radiator
Post  77f150 April 16th 2012, 10:00 pm
Can anyone offer a recommendation on a drop in quality aluminum radiator for a '77 F150? The old stock rad is near the end of its life and clearance is tight so a drop in would work best but hoping someone can point at a brand they had success with. Thanks.
77f150
77f150
Aluminum Radiator Empty Re: Aluminum Radiator
Post  kjett April 17th 2012, 8:45 am
Contact Joe Mayab he can hook you up Wink
kjett
kjett
Post  lghting94 April 17th 2012, 9:00 am
I went to oreilly auto not to long ago and their stock replacement was an aluminum cores radiator with the plastic tanks
lghting94
lghting94
Post  72puller April 17th 2012, 9:15 am
I put one of those in my pulling truck about 3 years ago, it has worked good and cools better than the old one did.
72puller
72puller
Post  77f150 April 17th 2012, 7:27 pm
We don't the O'Reily chain up this way, I'll look into Joe Mayab. Thank-you.
77f150
77f150
Post  Danny Cabral April 18th 2012, 4:13 am
This has been a great radiator for me:
http://broncograveyard.com/bronco/i-20608-bronco-aluminum-radiator-for-manual-trans-.html
Danny Cabral
Danny Cabral
Post  norm April 18th 2012, 7:34 pm
Danny Cabral wrote:This has been a great radiator for me:
this is the one i use,also.
norm
norm
Post  lghting94 April 18th 2012, 8:39 pm
I am sure that radiator is a great one but I would run down to your local parts store and see what they can get as a stock replacement, I believe most of them have went to the aluminum cores with plastic tanks.
lghting94
lghting94
Post  77f150 April 18th 2012, 8:56 pm
Thank-you for all your help, I'm going to pick-up the #20610 Auto Trans rad from Bronco Graveyard. I have a large auxiliary tranny cooler but was going to use the cooler in the radiator to help. Do you think this is overkill or unnecessary?
77f150
77f150
Post  Danny Cabral April 19th 2012, 2:39 am
77f150 wrote:I have a large auxiliary tranny cooler but was going to use the cooler in the radiator to help. Do you think this is overkill or unnecessary?
I believe a cooler in front of the radiator is more than sufficient and plumbing through the radiator's cooler just creates a restriction. (Looks messy too.) The Bronco Graveyard aluminum radiators are very durable and fully soldered (no epoxy). They're made by Heatex and they're high quality.
Danny Cabral
Danny Cabral
Post  77f150 April 19th 2012, 5:10 pm
Thanks Danny!
77f150
77f150
