Pro stock heads
+6
DanH
IcallhimGeorge
J R
10 posters
Pro stock heads Empty Pro stock heads
Post  J R September 23rd 2009, 7:18 pm
Will a set of them fit on a 460 wedge block 70s model.
J R
J R
Pro stock heads Empty Re: Pro stock heads
Post  schmitty September 23rd 2009, 7:22 pm
Which Pro Stock heads?
Post  IcallhimGeorge September 23rd 2009, 7:23 pm
Im thinking the power capability of the heads will far exceed the capability of the stock block in most cases but Im pretty sure they will physically bolt on as long as they are 4.9" bore spacing
dont hold me to this...I dont know much.
IcallhimGeorge
IcallhimGeorge
Post  J R September 23rd 2009, 7:33 pm
schmitty wrote:Which Pro Stock heads?
The nhra pro stock heads (65cc/4.600"/2.450"intake,1.880"exhaust)
J R
J R
Post  J R September 23rd 2009, 7:37 pm
IcallhimGeorge wrote:Im thinking the power capability of the heads will far exceed the capability of the stock block in most cases but Im pretty sure they will physically bolt on as long as they are 4.9" bore spacing
The hp will be bout 1,200
J R
J R
Post  IcallhimGeorge September 23rd 2009, 7:37 pm
a stock block wont go 4.600 bore so no.
IcallhimGeorge
IcallhimGeorge
Post  schmitty September 23rd 2009, 7:56 pm
IcallhimGeorge wrote:a stock block wont go 4.600 bore so no.
A stock block will go to 4.6" bore with a lot of work, ie. bored and sleeved. Not something cheap, but it can be done. Mike Lough has done a few, as I would imagine have others. I think Frank Merkl has a DOVE block that is bored way out there with 8 sleeves in it. As said before, the stock blocks are not going to live long with 1200 hp on tap. Vandy did more than that back in the day before performance blocks were produced, but the lifespan was what it was. Is this something that class rules or such dictate a "stock" block?
Post  IcallhimGeorge September 23rd 2009, 8:00 pm
Learn something new everyday. Thanks schmitty.
See JR, I told you I dont know much.
IcallhimGeorge
IcallhimGeorge
Post  J R September 23rd 2009, 8:42 pm
IcallhimGeorge wrote:Learn something new everyday. Thanks schmitty.
i see lol
J R
J R
Post  schmitty September 23rd 2009, 9:44 pm
We're all here to share the info. Cool
Post  the Coug September 23rd 2009, 10:05 pm
if you will check the head bolts are in a different position so no they won't work...
Post  Frank Merkl September 24th 2009, 2:14 am
my Dove-A block is not sleeved ( 1 sleeve only because the motor eat a rock on 1 hole) 4.505" bore -C460 heads with 1.850" ex valves with a slight radias on the top of the bore(down .200") for the ex valve clearance , 1428hp@7500rpm & 1006 ft/tq @ 7400rpm , would have made over 1500 hp@ 8500 rpm, but there were too many chevy boy's watching!!!!
Post  DanH September 24th 2009, 8:12 am
if your buying the raw castings from Ford Racing , bolt holes might be able to be located to standard pattern. valve seats same thing , can be cut for smaller valves. Have a lot of money on hand , and then some more $$$$$$
DanH
Post  Nevs September 24th 2009, 8:24 am
DanH wrote:if your buying the raw castings from Ford Racing , bolt holes might be able to be located to standard pattern. valve seats same thing , can be cut for smaller valves. Have a lot of money on hand , and then some more $$$$$$
Dan is correct, the bolt holes can be relocated on the raw E460 castings, but bring a LARGE billfold Exclamation Laughing Laughing Laughing Unless you are dead set on using them on a stock block, there are far more economical choices. Jmho...
Post  schmitty September 24th 2009, 8:30 pm
Frank Merkl wrote:my Dove-A block is not sleeved ( 1 sleeve only because the motor eat a rock on 1 hole) 4.505" bore -C460 heads with 1.850" ex valves with a slight radias on the top of the bore(down .200") for the ex valve clearance , 1428hp@7500rpm & 1006 ft/tq @ 7400rpm , would have made over 1500 hp@ 8500 rpm, but there were too many chevy boy's watching!!!!
Sorry about the mis info on your block there Frank. Embarassed I'm betting them bow tie girls were doing as much crying as they were watching. Twisted Evil
Post  the Coug September 24th 2009, 8:39 pm
lets just say this if you can't afford a new Prostock block then don't even think about buying a set of Prostock heads, because it is not a cheap head to build. They do not come with seats or guides or any other stuff for that matter and the cost to have it all put in and worked over is very expensive to say the least.
Post  Nevs September 24th 2009, 8:45 pm
the Coug wrote:lets just say this if you can't afford a new Prostock block then don't even think about buying a set of Prostock heads, because it is not a cheap head to build. They do not come with seats or guides or any other stuff for that matter and the cost to have it all put in and worked over is very expensive to say the least.
Exactly right, the blocks the cheap part Exclamation
Post  Paul Kane September 24th 2009, 9:14 pm
J R wrote:Will a set of them fit on a 460 wedge block 70s model.
What for JR? Are you building a real Pro Stock engine? If you are not, then a pair of iron CJ's will work better in your street build than the new pro stock heads EVER could. It's all about the most appropriate head for the package....not the "best" head.
Paul
Post  Paul Kane September 24th 2009, 9:18 pm
schmitty wrote: As said before, the stock blocks are not going to live long with 1200 hp on tap. Vandy did more than that back in the day before performance blocks were produced, but the lifespan was what it was.
For the record, Van did not have a passenger car cylinder block fail in any of those blown alcohol funny car builds. The engine's were high maintenance, yes....but aren't ALL funny car builds high maintenance? Smile
Paul
Post  schmitty September 24th 2009, 9:31 pm
[quote="Paul KaneFor the record, Van did not have a passenger car cylinder block fail in any of those blown alcohol funny car builds. The engine's were high maintenance, yes....but aren't ALL funny car builds high maintenance? Smile
Paul[/quote]
That definately speaks volumes for what these blocks can do in the hands of a person who knows his stuff about tune and setup. Cool
Post  RapidRuss September 25th 2009, 6:02 am
Damn Frank !!
Over 1500hp on a production block !! Whooo ! How in the hell do you keep the crankshaft from leaving the block ? By way of Billit 4 bolt mains ? and a damn good balance job to say the least !
Thats WILD Bud ! Cool
RapidRuss
RapidRuss
Post  rmcomprandy September 25th 2009, 10:27 am
Is this thread a trick question...?
Wat a waste of time, effort and money to even attemp this.
Definately NOT a bolt-on...
Post  DanH September 25th 2009, 1:52 pm
[quote="rmcomprandy"]Is this thread a trick question...?
Definately NOT a bolt-on...[/quote think they see the low cost E-head (pair of raw castings) and got the build of the year. don't need the Pro Stock block to use the E-head , can always do what i did.
DanH
Post  J R September 25th 2009, 8:34 pm
thanks gurus we'll just go with come cj's like everyone said it's a lot of $$$$$$$$.thanks again.
J R
J R
