Accusump
56Tbird
Race Ready Fabrications
Accusump Empty Accusump
Post  John Myrick April 17th 2012, 12:59 pm
Where's the best place to plumb the line into the block ( A460 ) at ? And what size fitting will it require ?
One my last run I noticed the oil pressure dropped at the end of the run, so I guess I better invest in a accusump.
Thanks for the help,
John
Accusump Empty Re: Accusump
Post  richter69 April 17th 2012, 1:05 pm
I went right into the port above the filter pad, it was a 3/8" npt IIRC
Post  Race Ready Fabrications April 17th 2012, 2:35 pm
richter69 wrote:I went right into the port above the filter pad, it was a 3/8" npt IIRC
X2, just plumbed mine to here last week.
Post  John Myrick April 17th 2012, 5:00 pm
The one next to where the mechanical fuel pump block plate is ?
If it is, I just have to figure out where in the hell to mount it in my engine bay
Post  richter69 April 17th 2012, 5:39 pm
if it wasnt a street car pull the wiper motor and stuff out and stick it under the cowl.
Post  John Myrick April 17th 2012, 5:49 pm
LMAO......has wipers....just no motor or anything else there Razz Razz Razz
Post  richter69 April 17th 2012, 5:52 pm
take um off, you'll have to cut a bit here and there but it will fit............
Post  John Myrick April 17th 2012, 6:00 pm
There goes my status as a "street car" with the wife lol! lol!
Post  56Tbird April 17th 2012, 6:41 pm
You could put it in the trunk if you want.It doesn't matter where you put it ,just takes a longer hose.
56Tbird
56Tbird
Post  John Myrick April 17th 2012, 6:56 pm
I just looked, I should have room in the cowl area. I did think about the trunk area but didn't want to run the hose that far
Post  rmcomprandy April 17th 2012, 8:18 pm
John Myrick wrote:I just looked, I should have room in the cowl area. I did think about the trunk area but didn't want to run the hose that far
Just mount it behind the grill, down low. It ain't THAT heavy.
Post  cool40 April 17th 2012, 8:30 pm
as much room as you have under the fender/apron area you may be able to get it hid under the fender,in front of the spring.i dont know how much room you'd need,i dont run one.
Post  BOSS 429 April 17th 2012, 10:09 pm
John Myrick wrote:Where's the best place to plumb the line into the block ( A460 ) at ? And what size fitting will it require ?
John
on that engine you want it in the rear of the block, not the front, because it will fill the oil filter before it gets to the bearings with enought oil
Post  Lem Evans April 17th 2012, 10:59 pm
Unless you have a dry sump system you will always have a "dip" in pressure.
John, at your speed .....I'd doubt you have an issue.
Post  rmcomprandy April 18th 2012, 12:20 am
John
on that engine you want it in the rear of the block, not the front, because it will fill the oil filter before it gets to the bearings with enough oil
Just be sure the filter has an "anti-drain back" flapper valve. If it's working, oil can't flow backwards.
Post  John Myrick April 18th 2012, 5:34 am
Lem Evans wrote:Unless you have a dry sump system you will always have a "dip" in pressure.
My "dip" was a big fat "0" on my oil pressure gauge.....getting the accusump for piece of mind
Post  BOSS 429 April 18th 2012, 7:45 am
John
NOW YOUR JUST BEING SILLY, THESE ENGINES (SVO) OIL FRONT TO BACK, LAST PLACE TO GET OIL IS THE REAR, IT DOESNT HELP TO PUT IT IN THE FRONT, YOU INSTALL IT IN THE REAR SO IT CAN TRAVEL( OIL THAT IS) TO THE FRONT FROM THE REAR FIRST WHERE WE KNOW THE OIL PRESSER IS LOW BEING OUR GAUGE IS READING IT THERE
THUS BEING THE REAR TO BE THE LAST PLACE TO GET OIL IT NEEDS IT FIRST WHEN THE PRESSER DROPS
Post  rmcomprandy April 18th 2012, 11:01 am
I will respectfully disagree.
The production rear only has an 11/32" passageway going to the gallery from a 1/4" NPT tapped hole, (an SVO block even has a smaller passageway), and the front has a 1/2" passageway from the 3/8" NPT tapped hole.
Unless the rear of the block is modified to be larger, anything more than a -6 line is not necessary. That size will not recover lost oil pressure as well, however it will keep some oil there under less gallery pressure for a longer period of time.
Post  Dave De April 18th 2012, 10:03 pm
You lost pressure after the stripe? and you have a front sump? I didnt think front sumps lost oil pressure at shut down unless all of the oil was up top.
Post  John Myrick April 19th 2012, 4:48 pm
A lot of oil at the top Dave
