Time to join the BBF club - 521" P51 build
Tommyj466
Injected65
Time to join the BBF club - 521" P51 build Empty Time to join the BBF club - 521" P51 build
Post  Injected65 April 17th 2012, 5:43 pm
I have been a small block Ford guy for years, but having listened to my boss and friends harass me about big blocks I decided that I was going to build one for myself to see what all the hoopla is about Very Happy This engine is destined for my 65 Mustang street car. The goal for the car is to have just enough power to get in to trouble but still be able to get on the highway and cruise for hours at a time. (Pump gas and a T56 speed will help)
Stock block
521" Ford Racing stroker kit courtesy of Lem Evans
Kasse P51 heads are on order courtesy of Kaase and crew
Kaase supplied solid roller cam (they haven't told me specs as of yet)
Victor Intake from Lem Evans
Ford Racing oil pan from Lem Evans
The motor should end up right around 10-10.3:1 compression. It will also be Fuel Injected and be spinning an alternator, power steering pump (with hydro boost brakes) and an air conditioning pump. The machine work will be done at Advanced Engine & Machine here in Salina KS. Marc Brown has built numerous BBF engines for people in this area. Hopefully if time and money allow I would like to get the motor on the engine dyno as well as the chassis dyno. Either way this should be one heck of an adventure. I will update with pictures and more info as things progress.
Thanks,
Chris
Injected65
Injected65
http://www.innovatorswest.com
Time to join the BBF club - 521" P51 build Empty Re: Time to join the BBF club - 521" P51 build
Post  Lem Evans April 17th 2012, 6:12 pm
What's the part # of your ATI dampner?
Post  Injected65 April 18th 2012, 9:29 am
Lem Evans wrote:What's the part # of your ATI dampner?
Man, you send a guy a bunch of money then he kicks you in the knees.. lol!
Here is a pic of the mock up damper I used on our PRI show motor this year.
Time to join the BBF club - 521" P51 build IMG_1274
Here is a pic of the accessory drive that we had at PRI too. Other than the C&C aluminum block my motor should look identical to this (especially since that motor had my pan, intake and accessories on it Very Happy )
Time to join the BBF club - 521" P51 build IMG_1246
Injected65
Injected65
Post  Tommyj466 April 18th 2012, 11:13 am
Cool build! What are you doing for front suspension to fit the big block? I look forward to seeing your progress.
TJ
Tommyj466
Tommyj466
Post  Injected65 April 18th 2012, 12:43 pm
I don't have any good pictures of the front end, but I installed a Rod & Custom Mustang II front end a while back. I just go the car back from getting new doors, quarters, trunk drop downs and mini tubbed. I am working on getting the motor, trans and 8.8" rear mocked up and then the car is due to be dropped off in Kansas City for final body work and paint this fall.
Time to join the BBF club - 521" P51 build IMG955049
Time to join the BBF club - 521" P51 build IMG956696
Here is a pic of the car from around 2000. I am planning on going back with the same original gold color but switching the interior from the tan to black.
Time to join the BBF club - 521" P51 build 00000059
Chris
Injected65
Injected65
Post  bruno April 18th 2012, 12:54 pm
very nice build Chris cheers
http://WWW.CKRME.COM
Post  dfree383 April 26th 2012, 2:00 am
that will be a real sleeper with a big block in it.
Post  Injected65 April 26th 2012, 9:08 am
That's what I am hoping for. I talked to Cliff @ Kaase's and he is prepping my P51 heads and also supplying the cam, oil pump and timing set for the motor. That only leaves me needing to buy lifters, pushrods, rockers, head studs, valve covers and gaskets and I should have all the parts to complete the motor. I'm starting to get excited. As soon as the top end parts show up I plan on getting some pictures of the parts and hopefully of some machined bottom end parts as well.
The rear suspension pieces are on their way now too. Thankfully things are coming together at a decent pace compared to the last few years stagnation. I also ordered a rendering of the car. That should be complete here in a week or so and I will have something to show off what the car should hopefully look like by next spring/summer.
Chris
Injected65
Injected65
Post  rmcomprandy April 26th 2012, 10:31 am
Just curious what you're going to do with your extra time now that you won't need to fix something with the engine every other weekend...?
Post  Injected65 April 26th 2012, 10:43 am
Ahhhh now common Cool The old small block was pretty reliable for what it was.
Time to join the BBF club - 521" P51 build P2180002
Once this motor is done and the car finished I am going to move on to my 62 Fairlane and start the buildup of a 480" E460 headed pro stock motor with twin turbos! affraid
Injected65
Injected65
Post  Injected65 May 2nd 2012, 5:21 pm
I received a nice little care package today from the guys at Kaase. Beautiful set of P51 heads, FRPP Timing Set, Kaase Oil Pump and a custom Kaase solid roller cam! I left my camera at the house or else I would have some more BBF porn to share. Maybe tomorrow... Cool
Injected65
Injected65
Post  jasonf May 2nd 2012, 7:11 pm
That is going to be a sweet car. What type of fuel injection are you going to run?
Post  jasonf May 2nd 2012, 7:14 pm
Also,do you have any more info on your accessory setup? It looks really nice.
Post  Injected65 May 2nd 2012, 11:12 pm
I haven't quite settled on an EFI system yet. I am leaning towards the new Holley HP system though.
The accessory system is one that we are developing for market at Innovators West. That is the initial prototype pictured. There are a few tweaks that we have done since that setup though. The finished version will be tested on my motor as well as a few other first before we start taking orders.
Chris
Injected65
Injected65
Post  windsor May 3rd 2012, 12:48 am
Injected65 wrote:I haven't quite settled on an EFI system yet. I am leaning towards the new Holley HP system though.
Chris
More info on that accessory system???...looks nice!
Post  Injected65 May 3rd 2012, 9:07 am
Chris
The goal is for a lower cost alternative to the other systems on the market currently. We are also trying to keep it a little less flashy I guess you would say. Less street rod, more muscle car. Initially we are working on the setup that will include the a/c, p/s and alt, but future versions will allow for less accessories. We are also starting with the BBF and then will work our way around to other platforms. The prototype shown looked decent, but i'm going back and working to move everything rearward a touch for more room at the front of the engine.
Chris
Injected65
Injected65
Post  jasonf May 28th 2012, 4:09 am
Well less expensive is definitely what I have been looking for. The $2500 everyone else wants is just retarded IMHO. I don't want or need polished billet aluminum. Straight up black powder coating would be fine with me. If you could figure a way to make it shorter would also be awesome.
Keep us posted.
