1966 f-100 with 460
1966 f-100 with 460 Empty 1966 f-100 with 460
Post  ed.bil April 22nd 2012, 8:41 am
can I put a tko 500/600 behind engine. it has a 9" rear
ed.bil
1966 f-100 with 460 Empty Re: 1966 f-100 with 460
Post  466cj May 1st 2012, 3:24 am
Yes, main question is what bellhousing you will use. Some require a spacer or a shorter input shaft.
466cj
Post  dfree383 May 1st 2012, 3:34 am
quick time makes a bell.
1966 f-100 with 460 Empty not to sound stupid. how do i tell which bellhousing i will have to use.
Post  ed.bil May 1st 2012, 6:49 pm
466cj wrote:Yes, main question is what bellhousing you will use. Some require a spacer or a shorter input shaft.
ed.bil
Post  466cj May 2nd 2012, 3:21 pm
dfree383 wrote:quick time makes a bell.
Yes quicktime makes several bellhousings for the BBF, so does McLeod, Lakewood used to, and of course there are factory bellhousings. You need a bellhousing that had the wide toploader bolt pattern. Quicktime does have one specifically for the TKO (it is deeper) and would not require any spacer or the shorter input shaft.
466cj
Post  GaryS May 2nd 2012, 4:13 pm
If you use a bell that requires the shorter input or spacer, use the spacer. Cheaper, leaves more room for a hydraulic throwout bearing, and locates the shifter back where you are. The right bellhousing accomplishes the same thing.
GaryS
GaryS
Post  466cj May 2nd 2012, 4:43 pm
If you measure the bellhousing depth from the engine face to the transmission face:
If it is 7-1/4" it will work with a TKO without any changes
If it is 6-1/2" you will need either the short input shaft or a 3/4" spacer.
Quicktime PN: RM-8010 does not require any spacer or input shaft change
The Short Input Shaft Kits (Tremec):
10-spline TKO 'FE' Input Shaft Kit (for TKO w/3.27 1st gear)................. TCKT5727
26-spline TKO 'FE' Input Shaft Kit (for TKO w/2.87 1st gear)................. TCKT5729
Spacer:
Mustang Unlimited PN: TRA650702 01
466cj
