mild motor --c4 or glide
yellowhorse7
johndickjr
mild motor --c4 or glide Empty mild motor --c4 or glide
Post  johndickjr April 29th 2012, 12:54 pm
putting the finishing touches on my car, its pretty mild compared to what most of you guys run, car is a 1992 mustang..no ac..heater box is gone..no ps..etc..motor is a stock lower end 302 with nice heads 308@.600 lift..intake and 248@600 ex...10-1 compression..hydraulic roller cam..from Anderson motorsport..N-91 cam..7000 rpm cam..gears are 4.88 , currently has 26-10 tires on it..right now it has a rebuilt c4 tranny and a bte 4500 converter..would it be better to use a glide or just stay with the c4..this is a 90% strip car
johndickjr
mild motor --c4 or glide Empty Re: mild motor --c4 or glide
Post  Mark Miller April 30th 2012, 12:17 am
IMO,Stay with the C-4 i think it would be a better choice with the small cubic inch engine and would be faster then the Glide.
Later Mark.
Post  whatbumper April 30th 2012, 8:33 am
depends on the future of the car in my opinion. if you are ever going to upgrade power then go with the glide. when I had my Maverick years ago we switched from a well built c4 to a rebuilt stock gearset glide with brake and picked up a little et, stayed the same mph. that was with a ~350-400 hp 302. of course the car only weighed about 2700lbs with me in it.
Post  johndickjr April 30th 2012, 7:15 pm
right now i will just be bracket racing it..maybe later thought about a single t76 turbo and gear changed and screw around with that
johndickjr
Post  yellowhorse7 April 30th 2012, 7:23 pm
johndickjr wrote:right now i will just be bracket racing it..maybe later thought about a single t76 turbo and gear changed and screw around with that
Then put a glide in it...
yellowhorse7
yellowhorse7
Post  QtrWarrior April 30th 2012, 9:06 pm
X2
QtrWarrior
QtrWarrior
Post  whatbumper April 30th 2012, 10:49 pm
yep glide. let me know when you need one and I will put one together with good parts that will live.
Post  whitefield April 30th 2012, 11:06 pm
If its all race car put a glide. since you already have the c-4 then run it untill she dies ! affraid
whitefield
whitefield
Post  dfree383 May 1st 2012, 1:03 am
C4 would be your best choice IMO.
Post  johndickjr May 1st 2012, 7:29 am
whitefield wrote:If its all race car put a glide. since you already have the c-4 then run it untill she dies ! affraid
thats the plan..i already have one, and a new bte converter
johndickjr
Post  2fox May 11th 2012, 1:52 am
whatbumper wrote:yep glide. let me know when you need one and I will put one together with good parts that will live.
pm me.with price.going 557 with.some.juice. no PGS here where I live at anymore.will need bell housing cut off it what's a conversation Capstone like the bell and FW? Thanks
2fox
