mild p51 combo
mild p51 combo Empty mild p51 combo
Post  79must November 26th 2009, 1:26 pm
I have a 502 using otb p51 heads, victorintake,flat tappet cam,850 demon vac sec,hooker headers using a powerglide in a fox body. It has been 9.79 at 137 but runs 10.00 mid summer .Its no rocket but has been a reliable bracket motor 2 years now. Jeff
79must
79must
mild p51 combo Empty Re: mild p51 combo
Post  jbozzelle November 26th 2009, 1:35 pm
Sounds like it's running like it should.
What's the car weight and compression?
Post  79must November 26th 2009, 1:43 pm
It weighs 3120 with driver.Compression should have been 12to1 ,but the pistons are 25 thou in the hole.It only pumps 170 on a compression gauge.
79must
79must
Post  jbozzelle November 26th 2009, 1:53 pm
Thanks. I'm buiulding a Mustang myself. Hoping to get it in the 9's and posts like these keep reassuring me that it will happen.
Post  jbozzelle November 26th 2009, 1:54 pm
BTW, Welcome to the site. Stop into the Intriduction forum and introduce yourself.
Post  79must November 26th 2009, 2:09 pm
Thanks john and good luck on your build. Jeff
79must
79must
Post  windsor November 26th 2009, 10:56 pm
Sounds like some great times! What are approximate cam specs, gear, and stall?
Oh yes, WE NEED PICS! Very Happy
Post  79must November 27th 2009, 9:16 pm
Its a comp catalog cam 272 276 650ish before lash. Gear ratio is 3.73 with 28 10.50.15 mt slicks. convertor is an 8inch coan approx 5500 .Im not sure how to post pictures. The combo is not matched perfect but it fits well in the 10.00 index class milan started last year.
79must
79must
Post  bigblockfox468 November 27th 2009, 9:22 pm
You from MI? We'll have to hook up Wink . I kinda got a simliar build happenin.
bigblockfox468
bigblockfox468
Post  79must November 27th 2009, 9:36 pm
Sure be nice to see more combos around here .Mostly stroked small blocks racing.
79must
79must
Post  FOXBODY101 November 28th 2009, 10:31 am
Thats sounds great this is what i am looking to build for the same class here at atco in nj...did you use engine plates or just the hooker kit with regular mounts i was thinking of using 4:10 gears do you think thats to low for that combo...thanks Doug
FOXBODY101
FOXBODY101
Post  79must November 29th 2009, 9:59 am
I used an AJE kmember that has its own motor mounts that set the motor down a bit and made some 1inch aluminum spacers.The steering shaft and hooker headers need extra work with this set-up.The 373 gears put me at 6600 at the finish line,So 4.10 gears would be a little to much.Hope this helps Doug Very Happy Post your progess this winter. Jeff
79must
79must
