71 460 Mustang Dyno Results
71 460 Mustang Dyno Results Empty 71 460 Mustang Dyno Results
Post  Mark460 May 1st 2012, 9:38 am
I ran my 71 Mustang on Dynojet 248 chassis dyno, with Richmond 5-speed, 4.11 gears. After jet changes and advancing the timing, it made, 406 RWHP and peak torque at 450 ft*lbs. Torque stayed between 450 and 400 from 3100-about 5200RPM. My combination is listed below.
Looking for comments, criticisms, etc. Do these numbers sound about right for this combination? I know the cam is small, I may consider another cam, but would want to keep something that I can still occasionally drive on the street. Thanks
DOVE heads, 2.19/1.72 valves, ported and flowed: In: 320@.500 , 340@.600 , 349@.700 Ex: 174@.500 , 191@.600 , 200@.650
10:1CR TRW L2404 pistons
Comp XE274 cam
Hooker 1 7/8 headers, 3.5 collector
Weiand stealth intake
Pro Systems built 1000cfm, 4150 carb
3in exhaust into Magnaflow type of mufflers
Fuel: VP ms109
Graph:
https://2img.net/h/i636.photobucket.com/albums/uu87/mnm3693234/newimage.jpg
Mark460
71 460 Mustang Dyno Results Empty Re: 71 460 Mustang Dyno Results
Post  LivermoreDave May 1st 2012, 10:51 pm
That's a nice combo. If I may offer a bit of insight? The cylinder head's numbers look great! That intake although has plenty of "eye appeal" will make your stomach churn if you flow it!
Dave.
LivermoreDave
Post  Mark460 May 2nd 2012, 10:28 am
Before I rebuilt this engine, I ran the same cam with a port-o-sonic and then I switched to the stealth. I could feel a "seat of the pants" increase in mid-range torque with the stealth.
Mark460
Post  dfree383 May 3rd 2012, 6:15 am
combo sounds fine, hows it go down the track?
Post  Mark460 May 3rd 2012, 7:49 am
I don't know yet, I'm planning to take it to the track in the next week or so.
Mark460
Post  res0rli9 May 3rd 2012, 10:52 am
LivermoreDave wrote:That's a nice combo. If I may offer a bit of insight? The cylinder head's numbers look great! That intake although has plenty of "eye appeal" will make your stomach churn if you flow it!
Dave.
Well whats a better or best duel plane ??
Post  LivermoreDave May 5th 2012, 7:16 am
res0rli9 wrote:Well whats a better or best duel plane ??
To answer your question, I'm not sure. I did see flow results of an intake like the one mentioned and the results were "eye-opening"! I sold a brand new Stealth (in the box) after viewing the results. If this combination was mine and cylinder heads flowing that good (heads mentioned), I would prefer a single plane intake manifold such as a well "massaged" Victor. When I look at the entire package listed, it seems to me the intake (dual plane) is out of place for top performance. On the other hand if this combination was just "putting" around the streets and idling through the drive-in, it would be fine.
Dave.
LivermoreDave
