Bad lifters?? Melling.
Recently a freshening of a 460 engine the owner chose to use Melling lifters on a used Elgin camshaft (real small chevy grind).
The engine fired and ran perfectly I ran in the first 30 min, no problem, good oil pressure, etc, sounded ok, dropped to an idle and the valve train was ticking.
Tracked it down to the #8-intake pre-load was perfect pulled the lifter (no visible cam wear/damage)and it just did not feel right on the bench so replaced it with a Seal Power. That problem solved we could now hear another lifter ticking...
I haven't seen a bad lifter in years, but I haven't used Stock Replacement Auto Parts Store parts in a long time, is this an issue with Melling?
Thanks for looking.
Chris
Thanks for looking.
Chris
BBF4xFord- Posts : 15
Re: Bad lifters?? Melling.
There is only a couple of lifter manufactures in the USA
dfree383 wrote:There is only a couple of lifter manufactures in the USA
Fully understand that but figured that without a name it would be like saying my new lifter tics...
The first question would be what brand...
BBF4xFord wrote:Recently a freshening of a 460 engine the owner chose to use Melling lifters on a used Elgin camshaft (real small chevy grind).
Thanks for looking.
Chris
Melling inexpensive OEM replacement lifter is probably from offshore somewhere.
according to my machinist, melling lifters are made by the same company that makes lifters for GM, he says they are great lifters
cooter- Posts : 220
» Jesel lifters vs Bushing Lifters
» Boss 429 broken roller lifter
» Boss 9 z-bar solid roller lifters
» FS: Melling HV Oil Pump (dyno time only)
» high flow dynamics melling 84d oil pump new in box
