950hp a460 block cooling
580ci, 950hp a460 block using alcohol,would a mechanical water cool it or would an oil cooler need to be added?
tconnection- Posts : 866
Re: 950hp a460 block cooling
tconnection wrote:580ci, 950hp a460 block using alcohol,would a mechanical water cool it or would an oil cooler need to be added?
I don't even have to turn my fan on anymore with alcohol
I dont even use a radiator on my injected deal, hell i got 2 block heaters and a heating pad on the oil pan I keep plugged in even in 115* weather. On alky hot oil is your friend.
Thanks alot men. Im going with the pain killer.
richter69 wrote:I dont even use a radiator on my injected deal, hell i got 2 block heaters and a heating pad on the oil pan I keep plugged in even in 115* weather. On alky hot oil is your friend.
Would just a pan heater be ok?
» cooling system size for 578 - cracked A460 block after all
» Cometic MLS head gaskets
» Differences between stock type block and the a460 block?
» distributer block hole is too small on an A460 block
» wanted a460 block or eliminator block.
