Tightening a converter with Hy-gard?
Finally got my new motor done and to the track. Motor is an absolute beast!! Getting this thing down the track may be a challenge....anyways, converter seems too loose to me. Goes 6200 wide open on the brake. I haven't been able to make a clean pass yet so I don't know the drop back on the shift yet. As I work out the chassis woes I'd like to calm the covterter down a bit without having to pull it right now.
How much should I expect it to slow it down? Should I just cut it 50/50 or do a complete change? Is the JD stuff at like Oreilly's the stuff to use or something else? Thanks Brian!!
Race Ready Fabrications- Posts : 619
Re: Tightening a converter with Hy-gard?
it will make a 200 rpm change at best, if its way loose it wont help much.
wow! where should it be? 6200 is a LOT! 8" converter?
cool40 wrote:wow! where should it be? 6200 is a LOT! 8" converter?
Yes it's an 8" converter. It was originally built for my 501 and went 5300 behind it. New motor is a 557 and makes a crap ton more power. I'd like to see it at about 5500 behind this motor. At 6200 it's uncontrollable on the start line......
time to step up to a bigger unit.
» Update-Hy-Gard made the converter too tight?
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» New Ultimate Converter Concepts Converter Test Results-Updated
» IN CAR VIDEO 7-16-10
» Hello from Canada
» Hello from Canada
