TFS 360 heads?
2fox
TFS 360 heads?
These heads only work on a aftermarket block?
2fox- Posts : 275
Re: TFS 360 heads?
If you want to use the 18 head bolts yes.
Re: TFS 360 heads?
They will work on the regular 10 bolt blocks, using only the 9/16" head bolts.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Re: TFS 360 heads?
what size as stock size head bolts? New at bbf sc.evans wrote:They will work on the regular 10 bolt blocks, using only the 9/16" head bolts.
Charlie
Heads make.the motor.right with.a.557 360 CC.would be the ticket or.would.340 work?
focused.about the BBC exhausted port.shy headers to get? For a fox BBC headers
2fox- Posts : 275
Re: TFS 360 heads?
I just installed accufabs, they fit pretty good.2fox wrote:what size as stock size head bolts? New at bbfc.evans wrote:They will work on the regular 10 bolt blocks, using only the 9/16" head bolts.
Charlie
Re: TFS 360 heads?
I'd use the smaller heads.
Re: TFS 360 heads?
you would....dfree383 wrote:I'd use the smaller heads.
Re: TFS 360 heads?
cool40 wrote:you would....dfree383 wrote:I'd use the smaller heads.
Yep...... Smaller is sometimes better, Port velocity = acceleration..........
Re: TFS 360 heads?
dfree383 wrote:cool40 wrote:you would....dfree383 wrote:I'd use the smaller heads.
Is such a thing as too much velocity. I'd find some old Motorsport heads and port them. Those TFS 360's are big even at 557ci, of course can just turn it higher...
466cj- Posts : 391
Re: TFS 360 heads?
466cj wrote:dfree383 wrote:cool40 wrote:you would....dfree383 wrote:I'd use the smaller heads.
Ding ding ding, winner!
kjett- Posts : 1169
Re: TFS 360 heads?
Re: TFS 360 heads?
cool40 wrote:dfree383 wrote:cool40 wrote:you would....dfree383 wrote:I'd use the smaller heads.
That's what she said........
» A429 Heads VS Dove-c Heads
